Under dash AC vent hose source?
I've looked all over the Pelican catalog, and even in the new parts diagrams and no joy. I finished a major overhaul on my AC today, nice 40 deg vent temps on my stock SC AC system and now I need to close one more hole. There are two little vents on either side of the dash, these connect to the air box with an odd size paper hose, anyone know where I can a replacement? The left side is crumbling away needs to go, cold air on my feet is not exactly where I want it.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
I know this sounds crazy but i replaced the hose going to my pass side dash vent on my SC with a section of shop vaccuum replacement hose. Perfect diameter, black ribbed plastic hose, kind of rigid. actually looks somewhat factory. also had nice cold AC blowing into footwells. no more.
one end was a little too tight (end that slips on vent), used a little heat and a pipe expander and snugly slipped it on. just a thought. I hear the factory ones are very difficult to find. Last edited by schoward; 08-31-2007 at 06:08 PM.. Reason: spelling |
Circa 2007 bump... Does anyone know what size hose goes to the small dash vents and where to get a replacement?
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Try Aircraft Spruce Brown Aircraft supply
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
911 571 228 00 about $ 11.00 You can order on Pelican
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
I ended up buying some 1.5 inch pool pump hose from lowes by the foot for a couple bucks. Worked great.
