Race motor& engine tin?
Does a race motor need engine tin around outside of motor?
Old 01-16-2019, 03:32 PM
All aircooled engines need the tin, the efficiency of the fan and overall cooling relies on it.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 01-16-2019, 04:14 PM
Hilbilly Deluxe
emcon5's Avatar
Yep, keep the hot side and the cold sides of the engine segregated.
82 911SC Coupe
GTI Cup #43
Old 01-16-2019, 04:16 PM
disband
juanbenae's Avatar
in addition to what's been suggested a ton of crud would make it's way into the motor compartment. weeds & dust should you or somebody else go off track dragging debris out onto the track surface. rubber slag finds it's way into all kinds of places, and simple grime from use.
try a search for Sheridan motorsports of paso robles CA. they produce some nice fiberglass engine shroud and tin options that might be up your alley if the tin is not in in your estimation.
Old 01-16-2019, 04:33 PM
Mahler9th's Avatar
No. I have run mine without tins or ill effect for 20 + years. I know many others that do as well. Many.
No issues with heat or debris.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 01-16-2019, 06:41 PM
Tin
I have run with out for 20 plus years on the race cars no issues, on a street car I can see the advantage with keeping the heat separated in traffic and debris
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 01-17-2019, 04:10 AM
The 9 Store
A lot of race cars run without tin. Can't do the same in a street car that is often stop and go and stop.
All used parts sold as is.
Old 01-17-2019, 04:58 AM
