Targa_PB_78_SC
Windshield washer passenger not work
I got the thingy off the nozzle see it in photo
![]() And there is no water at the hose (drivers side sprays fine). So I’m guessing it’s the “T” piece at the other nozzle (drivers side). My hose is pretty shabby so I’m wondering how to plumb the hose from nozzle to nozzle. Can I tie the new hose to the old one and then pull the new one through or do I need to remove some stuff? |
Can you blow air through the part you show in your pick? It’s a check valve and they get gummed up and won’t allow flow.
This was one of the first repairs I did to me car.
You may be able to reach under the cowl pull the hoses away from the retaining clips and access everything without removing the hoses. Flush cutters worked well to remove the Oetiker clamps. I took everything apart and blew through the parts, and it was the 2 check valves that were jammed (91462843300) No need to buy a new t-fitting (91162861700) or nozzle (94462807700) if you can blow through them.
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 01-03-2019 at 05:08 PM.. |
Targa_PB_78_SC
interesting, my hoses are a clear brownish and brittle (I see sugarwood's are braided). Thanks for the info guys, was not sure there are retaining clips, I'll look and see.
What ate your door pull?
'79 911SC Targa |
Fleabit peanut monkey
On my 81, I remember the 2nd check valve was over by the passenger side squirty and it was a one inlet piece. Like in the OP's pic. Maybe they upgraded the 3.2 for an easier maintenance adventure given the check valves are the common culprit?
1981 911SC Targa |
Targa_PB_78_SC
Targa_PB_78_SC
Thinking the fresh air fan in trunk needs to come out to get at the washer hoses? Or is there an easier way?
Someone else has had to have done it more recently than me.
1981 911SC Targa |
Just trace the hoses with your hand and see if you can untuck them and pull them forward into the bay. You may also need to detach the hose from the actual washer nozzle to create play. Nozzle attaches to cowl ....retained by a squeeze tab. Once you loosen nozzle, you can lift the spray nozzle up away from the car. This will expose the connected hose, which you can try to disconnect from above (rather than reaching under the cowl, and trying to disconnect blindly)
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 01-04-2019 at 05:45 PM.. |
Targa_PB_78_SC
Can't find the squeeze tab on my nozzle. Hum. thanks for the update. I did find a tab (one of those bend style tabs in front of the oil pressure gauge) for wiring/hose on drivers side which was binding on my pull of my old brownish washer hoses. Fortunately, for removal, there are no clamps on the '78 hoses.
My check valve on the passenger side seems fine, blows only the correct way. Still working to get the drivers side off the nozzle for a test. There is not an easy position for us old guys to reach under the cowl standing on the floor. I guess I need to climb in the trunk to do this. Funny what I'm going through to fix the passenger side sprayer when it hasn't worked in 20 years and I never drive my Targa in the rain .
Targa_PB_78_SC
Well I got the new tubing and squirters and two way valve from Pelican.
The passenger side nozzle came out with wire cutters easy enough. The drivers side nozzle was a real pain to get to but after much cussing it finally came out. Then the outside squirters/nozzles holes proceeded to wet down my garage floor. They were adjusted by moving the eyelets with a sharp probe. This shows me why I’ve lived with only drivers side squirters for 34+ years ![]() PS the hole in my 78 (for the nozzle) is much smaller than the one shown for an ‘86. Maybe too much complaining about repairs on the older ones. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Passenger side sprayer.
The driver's side sprays like a fire hose.
However the passenger side is not receiving water to the nozzle. I can "pulse" the washers by using the stalk, and get a bit of water to the passenger side, and, that's it. I can blow through the nozzle, but the lack of water delivery seems to be the issue. Thanks in advance, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Check valve
![]() ^^^^^ This is the line that feeds the pass side washer. How to replace? Thanks in advance, Gerry
How to replace?
Use micro flush cutters and remove the clamps And replace clogged parts and get new hose clamps
1986 Bosch Icon Wipers coupe. |
Those look like oetiker clamps. Single use and require a special plier to instal. No big deal but you would need the right size clamp and pliers. Or zip ties are your friend.
Window washers.
O.K. guys-
Got it, and thanks for your ongoing support. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 01-19-2019 at 11:19 AM.. |
