Strut Bar Benefit Testing Before and After
I've always been curious and a bit skeptical about the installation of strut bars in a 911.
I was also curious about the effects of seam welding, so I devised a method to measure the effectiveness before and after. That thread is here: http://forums.pelicanparts.com/porsche-911-technical-forum/1015116-seam-welding-works-before-after-testing-video.html This week I repeated the torsional rigidity test with the addition of a strut bar (Both the two point and three point variety) This weeks video is really long, sorry about that....so here are the results: 1) Increased torsional rigidity is about 10% 2) Max load in the horizontal bar was measured at 70 lbs 3) The loads alternate between tension and compression 4) Changes in camber are very small with or without the strut bar I will repeat this test when the car is driveable, but I stressed the chassis a lot. Almost 1500 ft-lbs, I dropped the car on purpose and drug it across the floor. Another great thread on this topic is here: http://forums.pelicanparts.com/porsche-911-technical-forum/399470-lateral-stiffness-911-front-strut-tower.html I tend to agree with burgermeister that the strut bar in a torsion bar 911 isn't that effective. I would love to hear your opinions otherwise. Have you noticed a seat of the pants difference with either a two point or three point strut brace? Here's the link to my video: <iframe width="560" height="315" src="https://www.youtube.com/embed/QjGYaeYew8s" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
Like your videos--great stuff.
Wow, actual strut bar data! This should end the controversy once and for all. :cool:
I believe the strut brace can have some benefits. Especially if you are running wide sticky tires on the track in a long hood. In my case I put a lot of tension on my bar, pulling the strut towers closer together aiding in more neg camber. Edit, it should also be mentioned that the rubber upper strut mounts will allow more movement of the struts than the actual towers. So with out mono balls a strut brace may not have much affect. |
That’s a pretty informative video. I recently bought a aluminum X brace ala 935 for my 930
I have to admit it was mostly for the cool factor. Years ago a retired factory Porsche mechanic told me the benefits of a single strut bar were slim to none. I think it would be interesting to see your test done with the X brace. I gotta believe that the Porsche race team used them for a reason. Although, as you pointed out in your video the difference is probably far greater on the track. When’s the sanding video? :D |
Tom , once again , well done and thanks for your efforts . I believe that that making a chassis stiffer and more dimensionally stable happens with the collective from all the efforts. The same as with weight savings . Gold star results !!!!!
Icarp |
I agree that the rubber donuts give much more than the strut towers do. The torsional rigidity test I did doesn't care if the strut is connected to the tower with rubber or mono ball. I also don't think mono balls change the actual force that the strut tower sees. You might transfer more vibration and load spikes, but the cornering loads and damper loads have to goto the same place. The rubber connection just allows the strut geometry to change more, that's all. Like Burgermeister said and I agree don't expect the strut bar to help much with camber control. Monoballs are much more effective at controlling camber. |
Here are my thoughts on the 935 X brace: 1) I respect the factory and believe there's a benefit 2) I'm confident that the X brace over the spare tire would improve the torsional rigidity. (in my setup). Note that I measure the torsional rigidity at the suspension pan front pickup points which isn't really fair! Those points are not as strong as the front crossmember attachment points. Even though it would show an improvement in my test setup doesn't mean that it will change the way the car drives significantly. The forces in the front pick up points are very different than the rear ones because the location where the strut attaches to the suspension arm (biased toward the rear). The front points experience braking loads that try to pull the suspension mounts wider. There isn't much force in the front up and down wise. The X brace may not help much with cornering loads??? I'm not sure. I'd love to know more from experienced racers and engineers! I was planning on adding an X brace too, but after this weeks results, I'm re thinking the effort versus value. 3) The 935 was a coilover car right? There is a lot more force in the strut towers with coil overs versus torsion bars. 4) The original 935 brace I found a picture of didn't have a diagonal bar between strut towers. The X brace becomes the triangulated support. Perhaps the diagonal bars in the same plane as the towers is redundant if using an X brace also. |
As far as the hood gap, well that is a long story. Many years ago when I only drove on the street and my car was very low, I was concerned about too much negative camber. To correct this, I used a strut brace to jack the front strut towers apart. IIRC it amounted to almost one degree. At that time the hood gaps were noticeably larger. Now, since I autocross, I have done the opposite. I have Heim joints on the ends of my brace and use it to jack the struts together. I never measured it, but I would guess we are talking about over 1/2" total. My hood gaps look fairly normal now, but it also increased the curvature of the cowl, which was a good thing.:D I can gain 1/2* or more negative camber using the strut brace. BTW, I believe the impact bumper cars are much more rigid to begin with, too bad there can't be a comparison. I also used thick machined washers on top of my rubber strut bushings to limit the struts movement. |
good work
As was the 73 rsr . If you are saying the only forces on the front points are from braking , and the force is from front to back only , you must only brake when the wheels are facing straight ? I do the same in my garage ... I might be a little drunk , but I kinda remember a porsche Motorsport engineer telling me the d-zug/x-brace was only added as an headlamp support for night racing (winning lemans etc) and as a belt-and-braces effort to help support bad welds . I allways thought it was only fitted to stop fiberglass hoods having a huge dimple at speed . :D |
Combined with mono balls, I use the strut brace to gain a little bit more negative camber by preloading it in tension.
I love seeing actual data!! Thanks!
Also love your equipment! Is there a source for reasonably priced load cells and associated equipment? I could see that coming in really handy! I must admit to using a 2-point turnbuckle style struct brace on my car … I use it to get an extra -0.3 deg of camber, apparently like many others :)! That's as much as I personally am comfortable with - I don't want to bend anything permanently. It's visible in the hood gap if I look for it, but otherwise not. I ran a blind test once - I set the brace to zero load (so no additional negative camber) and had a friend randomly connect & disconnect it over 3 or 4 sessions in the morning. Neither I nor the data I took could tell a difference. I was running RE11's at the time. Also once upon a time I made a very flaky attempt at measuring the torsional stiffness of my 911 chassis. I got 5200 ft*lb / deg, likely on the low side of the ballpark - all the errors & unknowns, and there are a lot of them, would tend in that direction. But pretty silly by todays standards even if my error is 50%. That said, it's significantly stiffer than the roll stiffness at either end of my car (22/29TB & 23mm SmartRacing ARBs), and thus sufficiently stiff to allow tuning the lateral load transfer distribution. http://forums.pelicanparts.com/porsche-911-technical-forum/404335-torsional-stiffness-1988-911-coupe-3.html |
About the up and down loading of the front suspension points: Even if you are braking and turning the up and down load is small compared to the cross member attachment. Sure you can load either front tire by braking and turning, but the location where the strut attaches puts most of that load at the rear suspension pickups. The front points do take a lot of braking loads but they act from side to side. The X brace would work better for up and down loads. |
I have to ask, why not use offset ball joints or slot the camber holes/modify the camber plate for more camber? |
Personally, I never trusted the offset ball joints - I have not seen sufficient data to trust my skin to them. The 911 loads the balljoint in tension, and creating an offset in the same space necessarily means a smaller - and thus more highly loaded - ball, custom aftermarket parts do not necessarily have the greatest quality control or reliability testing ...
Modifying the camber plate only goes so far, then the shock hat interferes with the body. Removing the shock hat helps a little more - but then the jounce bumper loses its efficiency. One could make a custom jounce cup to restore that, but then the shock rod is still exposed - bad for the seal if one lives on a dirt road in a state where rain is pretty common. And the shock body still has to clear everything. The strut brace seemed the easy path - low cost, reversible, near zero cost if you have a welder and some time. What I wonder is why there are no +10mm span lower control arms. Liability might make it financially unattractive to make such a thing of course, and it precludes running wider tires on the front as well. Also, see 1) above. |
I am also use tarret offset camber plates. And I took the strut sleeve off and replaced it with a rubber bellows.
Have not stepped up to raised spindles or offset ball joints. Car had the Weltmeister bar and rubber bushings when I bought it. So I use what I’ve got. |
Connecting the instrument needs a GPIB to USB adapter which is a little harder to find. The black thing with red wires is just a 5V power supply, but its very stable which is good for strain guages. If I had more time, I could configure the data acquisition system to cancel out power supply variation. Load cells are also on ebay, but might be best to buy new or at least check the calibration. Mine is an old general sensors brand Nice work on the torsional rigidity testing! These cars are a little flexible! Thanks for your blind testing results too. That is what I was looking for to confirm my theory. Awesome.... |
I'd rather fabricate new dust covers than mess with my hood gaps. That's just me and my obsessive nature. Thanks for chiming in, I love the discussion and learn something new everyday. |
Not trying to be critical, but I see a couple of questionable elements to your setup and test. First, I question why you cut and instrumented the top brace in the middle of the brace? By so doing, you create a "pin" in the middle. In tension, this is not an issue, but in compression it would significantly weaken the strut/brace. For the loads you are seeing, I suspect you are nowhere near the buckling force (again, in compression) of the brace, so you would not measure much difference. At more extreme loads, the strut or brace would deflect under compression, creating a weak system, and in theory, a collapse mode. A better (but not ideal) solution would have been to move the load cell to the end of the brace, where there is already a "pin".
Secondly, the addition of a diagonal for the loads you showed earlier in your video will not see much if any load. If the top strut/brace is in tension or compression, the diagonal sees no load. Only if there is a vertical load at the strut tower applied to the system (acting perpendicular to the top strut/brace) will the diagonal see any load. Also, if the diagonal sees any vertical load, it all ends up at the lower diagonal attachment point. If you are designing for some vertical applied load at the strut tower, you should have a diagonal in each direction or cross. So, in summary, for the loads you have described in your video, the addition of the diagonal has no or little effect on the torsional rigidity. If the top strut/brace is significantly loaded, the strut/brace would collapse under compression. I offer this commentary for your consideration. |
Regarding the buckling: I agree with your placement of the sensor recommendation that relocating on the side is a better choice for high loads. But as you say 70 lbs is no where near the buckling strength of the bar/sensor setup. So, if I did this test again with your consideration, I would get the exact same results. Regarding the diagonal bar forces, I'm not clear why you think there is no load in the diagonal when the chassis is twisted. When the diagonal bar was connected the deflection dropped by 9%. The top bar did have some load as I showed on my computer screen, but I think the results speak for themselves: The diagonal bar improves torsional rigidity and a second diagonal bar or X may further improve it. Your vertical load scenario in the strut only comes into play when I dropped the car on the right front tire. The strut doesn't have any springs in it and only transfers vertical load through the damper piston/fluid design. I wish I had second load cell because several questions about that have come up. However, I feel like I've learned enough about this that I can make an informed decision on how to proceed. I will size the top bar to be fairly lightweight but will avoid buckling and I will add a second diagonal bar in an X configuration. Cheers, Tom |
The diagonals, much like building diagonals, only see load due to forces perpendicular to the strut/brace. (A building lateral system is your system, rotated 90-degrees, and diagonals are for lateral forces such as wind on a building.) I would agree that the addition of diagonals would increase torsional rigidity, but my comments were in reference to loads you described earlier in your video (you only showed loads in one direction). I think there is differential vertical displacement of the strut towers as the car flexes, thus creating a vertical load component at the strut towers. The actual load path is probably very circuitous so I think it's a bit more complicated than you originally described, but your point is well-taken: the braces will aid in torsional rigidity.
Yep, I thought in your first message you said that the diagonal bar doesn't contribute to torsional rigidity. In terms of vertical loading due to the deflected shape isn't a big load compared to the reaction forces from the the strut. If you look at the cross section of the cars construction through the shock towers you see will this: Under the horizontal line is the deflected shape. Notice the double shear boxes. Now even if the shock towers displace up or down, the strut does little to constrain it. The same deflected shape is typical during torsional stress. http://forums.pelicanparts.com/uploa...1548112923.jpg |
Curley
If one looks at the load paths, doesn't the top of the strut take very little force in a horizontal direction compared with down at the A arm? This is why I have always been suspicious of getting much benefit from strut bars. Of course, for a full on race car, you want even the small benefits. And there doesn't seem to be any significant disadvantage to go along with a strut bar. A straight across bar has to benefit from a fixed diagonal in the vertical plane, so the forces on one side aren't just transferred to the other side, doesn't it? Again, maybe not much. An X or equivalent would be better (I did that on my track only car in a class with few restrictions), but as long as the loads are transferred to a stronger point, maybe a single fixed diagonal is enough. It may be that the relatively low forces involved mean that the hinge pin effect of the strain gauge attachment doesn't matter? Tperazzo, if he knows more about force paths than I do (which is not hard), reinforces my take about the front suspension mounts. The leverages with respect to those versus the forces at the axle are even more favorable to their not needing to be reinforced. Braking pushes the A arm backward. Vertical forces up front have to be inconsequential. If braking can try to pull the front mounts apart, well sheet metal does just fine resisting that, and the flat tubular sheet metal structure is plenty strong in compression as well. I like the theories about the factory X brace. A race shop owner told me he favors it because it stiffens the front in case of collision, leading to somewhat less expensive repairs. I have the strut brace on my SC cranked in as far as the hood/fender allows, just short of rubbing on one side. I wish I could get more negative camber. If class rules allowed, I would widen the A arm in a flash. Easy enough to do if you can weld, and plenty strong. Because any shop could do this, there wouldn't really be a market for it, would there? |
I agree with you Walt regarding everything you said about the upper shock tower loading and the front suspension pan loads.
Even though the X brace over the spare tire area may help save the car in a crash, I've also been warned that the X brace could be dangerous in a crash if its welded in the center and the car doesn't have a full roll cage. If I remember correctly the concern is that the bar could get pushed into the drivers area through a gauge hole. I hope that didn't happen to someone. Yikes. |
Well that settles it.
I’m ditching the STB so my Golf Clubs fit in the frunk again. Sent from my iPhone using Tapatalk |
All I know about a "normal" strut brace is that I have never felt any difference with or without them. Pulling the body together for camber is another thing.
My comments were directed at the loads tperrazo described in his video, showing only horizontal loads at the shock towers. My belief is that the very nature of the shock towers (to stabilize the shocks) are loaded both vertically and horizontally. The shocks definitely see a vertical load component to bumps as the strut compresses and extends. The shocks are not vertical - they are cambered so there is also a horizontal component loading as well. Ideally, a bulkhead across the trunk would make that area torsionally very rigid. However, the impracticalities of this in a trunk negates this - no golf clubs! I am also not arguing that a strut and diagonal are necessary (unless you regularly track or race) - let's not forget, Porsche has the best engineers and they analyze the structure for loads that these cars experience and design accordingly. I would think that only in hard cornering while tracking and racing would any real benefits be felt. But I would agree that adding a strut/brace and diagonal braces would enhance torsional rigidity keeping the geometry of the struts and wheels as the designers intended.
Good video to dispel the dreams of road race stardom.
My low buck, DIY 10% mod performed on a Weltmeister strut bar a few years ago: http://forums.pelicanparts.com/uploa...1548202385.jpg http://forums.pelicanparts.com/uploa...1548202385.jpg http://forums.pelicanparts.com/uploa...1548202385.jpg I'm probably 10% poorer, but it's shiny and I'm still delusional. I agree. There are probably better methods of increasing negative camber without using brute force. Sherwood |
I'm not judging either way, its just that there is a wide range of thought on these things. :) Nice work on your modified brace Sherwood! |
The lateral strut tower forces were described when purely cornering. You are correct in the real world there are bumps in corners, however for the sake of experiment design these components were isolated into three different experiments as shown in the video. |
Great video and work, thanks. I just wish you did this testing before the seem welding was done. I believe results may be slightly different if you had?
Jeremy - this may be a good point, but as I recall the results are consistent with what Burgermeister did? And his car wasn't seam welded (though neither was the wall of his garage).
Once this car is ready to drive, a day at a DE - or even an autocross - with the strain gauge bar in place and hooked up to a data recorder, should be even more informative. Long ago - perhaps before the PC? - the makers of a strut brace (Automotion) instrumented a car with dial indicators with a telltale. Their conclusion was that the change in location of the shock towers was outward. Based on this, the brace they sold was just a bar taking up tension forces. A competitor (Stable Energies), who made (and makes) a strut bar system which has a diagonal (and is carefully designed to fit rules which prohibit welding in or otherwise messing with the sheet metal to create attachments)disputed this, but did not offer data. With the introduction of the Boxster tub, there is no need to do any of this, at least in the side to side direction, as the tub comes up pretty much to the top of the tower. |
http://forums.pelicanparts.com/uploa...1548386567.jpg Seam welding isn't a magic silver bullet to be honest. I think the seam welding and strut bracing yield comparable results (18% and 10% respectively in torsion). Believe me, the car is still plenty flexible despite the seam welding. If it was a full race cage tied into the suspension, then I would say, "Yeah, not fair!" |
That is consistent with what I measured when dragging my car across the garage floor. The strut bar was in tension meaning at least one tower was trying to move outward. I only got 5-10 lbs in the bar with this test, but I hope to try again by driving the car on a track. Thank you, Tom |
Wouldn’t the load path be from the axle to the a-arm mounts, with any multiplication factoring coming from the distance the axle is relative to the a-arm pick up points? The strut towers are for shock absorption mounting and some small lateral deflections.
Side note, I have the x brace aluminum mounted, and while driving in the rain the windshield gasket woul weep, took it out and dry as a bone. Putting it back in now that the fuse panel update is finished, will go slip sliding in the rain to test. Moving stiffness around means forces are focused in a way that the factory never engineered for. |
As far as the up and down loads go, the strut tower is very strong in this direction because the metal is in tension instead of bending as with the lateral forces. Thanks for sharing that experience with your windshield! Wow, that's pretty crazy. Did your X brace have heim joints on it to tension the tub? Thanks Tom |
Prior efforts were modified Weltmeister units. I have 2 sets of Weltmeister brackets that were torn apart while using rubber bushings. There is plenty of force being transferred while driving. I guess my point was/is there many forces present and moving them from one point will just transfer the forces to the next weakest point in the load path. Everything from the front suspension to the rear, is in the load path, and I would imagine anything outside those points could be contributing to stiffness via boxing/triangulation. |
| All times are GMT -8. The time now is 12:19 AM. |
