Targa_PB_78_SC
mike sampsel's Avatar
Rear shock gap difference paranoia
I have an apparent difference in shock bolt gap.
[img]
The passenger side has bigger gap. Both were torqued to the 92 ft-lb, although I raised the trailing arm with floor jack per Wayne’s method versus Bentley which implies tighten with weight on wheels.
Concerns? I’ve driven it 2400 miles and 12 months without issues.
Old 01-21-2019, 06:48 AM
Harpo's Avatar
I would add a paint stripe connecting the head of the bolt to the washer and to the shock. This way it will be very obvious if it loosens up.
Old 01-21-2019, 06:54 AM
sugarwood's Avatar
If you're not getting a rattle, the shock works the same.
It dampens the recoil.
That lateral movement would not really many any real difference.
Is the bolt head bent?
Why not replace the bolt ?
1986 Bosch Icon Wipers coupe.
Old 01-21-2019, 07:19 AM
Targa_PB_78_SC
Why didn’t I think of this? Good idea
Old 01-21-2019, 07:26 AM
That Guy
Techno Duck's Avatar
Did you check how the gap looks with the wheels on the ground? That gap will probably go away.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-21-2019, 08:11 AM
Targa_PB_78_SC
Well, I had new porsche bolts so I replaced the passenger side bolt. Threads on the old bolt looked a little warn. Then a omen came as the interior washer between the shock and the trailing arm lay on my garage floor. Suspect there is not a washer between the shock and the trailing arm on the drivers side; hence, less gap on drivers side. I seem to recall no washer present when I installed before, did not annotate though.
Added paint to passenger side. Consternation on adding a washer to drivers side. Thanks for all the thoughts and advice guys.
Old 01-21-2019, 10:15 AM
Remove the bolt turn the shock 180 deg.
Old 01-21-2019, 12:17 PM
