Oil tank restoration
I’m wanting to remove my oil tank from my 1970 911 ,is this fairly easy .Once out what’s the best way to restore it ,what type of paint do you use or can it be powder coated
I’ve looked on line to see if any one has posted a how to video but couldn’t find one
Old 01-20-2019, 07:11 AM
Mine is in the parts washer and I was just thinking about this 5 minutes ago. I have powder coating eguipment however i think I'm going with paint due to prep, and the fact that there's a few different metals and I'm not sure how powder would work out. I'm going with a 2 part epoxy primer then some flat or semi black paint.
Old 01-20-2019, 07:35 AM
Ctopher's Avatar
I would suggest a semi/satin as a flat will show oil spots as shiny and won’t clean up as nice as a satin.
But I suggest doing a ceramic coating instead. They are baked on and nearly impervious to chemicals and should last till the next restoration many many years from now.
Ctopher
Old 01-20-2019, 07:43 AM
kfosburg's Avatar
Send a message via AIM to kfosburg Send a message via Yahoo to kfosburg
I did POR-15 on mine and it came out pretty good. Very tough stuff and should be easy to keep clean due to the gloss.
Karl
Old 01-20-2019, 07:46 AM
How easy is it to remove the tank ,and what’s the best way to clean the inside
Old 01-20-2019, 08:21 AM
Most decent independent Porsche shops can wash it out and in the process, most of the original paint will come off. Any paint left will either pick off or is on tight so Por over it.
Scuff it lightly being careful not to remove the cooper coating. Por15 satin/matte finish; spray or brush. Por15 tends to even out smooth on it's own. One side then the other. Prime & paint the sending unit.
65 356SC Cab - 70 T Sunroof Coupe - 82 SC Targa - 86 Coupe - 87 Targa - all sold years ago
89 944S2 Daily Driver-Sold because...still thinking why.
73.5CIS Targa Shed Find -On the Road Again
Old 01-20-2019, 08:36 AM
kfosburg's Avatar
It's not too bad to remove... drain it, remove the right rear wheel, loosen the fender reinforcement, remove the nuts and breather hoses inside the engine compartment, remove oil filter. Disconnect oil lines, level sensor wires from fender well... Then, it rotates out - takes a bit of fiddling, but not too bad.
Cleaning - take it to a local radiator shop is probably the easiest way. I chose to just use water, detergent and elbow grease. Careful removing the level float - it has some small wires on it.
Pelican has all the rubber donuts, washers, and other rubber parts to make it nice when put back in.
Karl
Old 01-20-2019, 08:37 AM
Thank you everyone for your help ��
Old 01-20-2019, 08:57 AM
911tracker85's Avatar
I am about to attack my oil tank for my project, already have it out. but intended to do some research first.
so it has copper coating? where, whole thing? my intent was to PC it, and the shop that I use first does a chem strip, then blast clean before PC. and they are good plugging any openings when blasting and applying the PC. I am going satin black on everything I have PC'ed.
will be watching this thread for ideas and cautions.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 01-20-2019, 11:19 AM
The 9 Store
I powdercoat them. Remove paint with paint stripper, glass bead blast just enough to give it some "tooth" but not enough to remove the copper, powder coat. Then it gets rinsed a couple times, dropped in an ultrasonic cleaner, and rinsed again, just to be sure. Cerikote would be a great option but I like the powdercoat since they usually are somewhat corroded (east coast) and the powder smooths it out.
The original ones have copper inside and out. The reproductions are not usually copper coated.
All used parts sold as is.
Old 01-20-2019, 02:59 PM
Shaun @ Tru6's Avatar
I always Cerakote oil tanks, use 2 coats. Any imperfections are filled for a beautiful finish. There is a new heat dissipation Cerakote that I'm eager to use on the next tank.
Tru6 Restoration & Design
Old 01-20-2019, 03:05 PM
Ctopher's Avatar
This is what I was thinking. I’ve already applied the heat dissipation cerakote to my oil cooler and oil lines. Next down the list is the oil tank and condensers.
Ctopher
Old 01-20-2019, 03:15 PM
and considering the location it does get a lot of abuse. guess this is another item I'll be sending you......
Bob Cox
Old 01-21-2019, 05:26 AM
Harpo's Avatar
What about these guys
Capabilities List
Old 01-21-2019, 06:41 AM
The 9 Store
Capabilities List
They have long been known as the "go to" for oil cooler and tank cleaning.
Old 01-21-2019, 08:12 AM
That Guy
Techno Duck's Avatar
Pacific Oil Cooler cleaned and refinished the tank for my '88. They did a nice job. I think all they use is a high temp black paint.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-21-2019, 08:18 AM
Carefully check for cracks in the two welded mounting pieces that fit on the body. This are can crack and you will suddenly find oil on your garage floor after a warm up. This happened on my 1973.5T tank. After having it flushed out at a radiator shop, I used two coats of POR 15 black. If you want a rock hard long lasting coating use the POR 15 product. Your tank is hidden and no need to make it a fancy color as no one but you will know its their! The tank get bombarded with stones and rocks chips and debris. Use a hard finish to preserve it.
Old 01-21-2019, 09:48 AM
This thread is timely.. planning on tackling my tank this spring.
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 01-21-2019, 09:52 AM
911timesThree
rolfjahn's Avatar
Wurths, change the sender while its out-gauge responded smoother was jumpy before
1987 911ST 3.4L G50 LS 20/21 Granite Green Hot Rod
1988 911 3.4L G50 LS 20/21 Guards Red Hot Rod
2020 F87 M2 Comp 6Speed Carbahn 562/567
Gone: 1991 965 Black/Black Turbo
Gone: 2002 E46 M3 6Spd CSL style build
Old 01-21-2019, 09:54 AM
Shaun,
scrubbed it up and got most crud/oil off. is this the copper coating peaking through? from road debis it does have some areas of surface rust.
will be shipping in the next day or two.
Bob Cox
Old 01-23-2019, 10:52 AM
