Do you think that my struts are cooked
Hi guys,
I'm rebulding my front axel unit. I was wondering if my struts are good enougth to continue a little bit or not? There is a little gap which I can fell with my nail? Thanks a lot .Have a nice day.
Street car? I would say get a Tap/Die, find the right size die (thread pitch by matching to the bolt that goes on those threads), chase the threads to clean them up and toyota re find. I believe there is usually a gap below the threads on struts. I just has mine out yesterday (wiper seal nut came loose, not good), but did not specifically check this.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
It's a 914 ...
If the gap is right by your nail, there should not be a gap or ridge there. That can happen if there was some malfunction with the bearing and the bearing race spun on the spindle, or perhaps someone used a chisel to remove a bearing race at some point. Take a micrometer to the spindle and see if it is out of round there. Ridges in spindles can be stress risers and cause the spindle to fail at that spot - not what you want!
Spiderman
If that's right where one edge of the inner race sits I'd be suspicious that its moving for some reason like the bearing wasn't tight and peened in the metal. Just for knowing, is it all the way around or just in a certain area ? For street use I'd guess it would not likely be a problem (as long as its not a crack ) if the bearing can still be tightened correctly but for strenuous use, not as much.
An opportunity to do something new/fun with the front struts like lowering, new shocks, coil overs, on and on.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
It's on both sides but not all the way around.
By the way, it's a street car configuration with Elephant & Racing rubber bushing, bilstein turbo shock absorber, new master cylinder. |
911T '72
Looks like the inner race from the outside wheel bearing has spun on the stub axle. You probably won't be able to get all of the play out of the wheel bearing as it can tilt in the groove. For me they would be scrap. Or you might be able to find a engineering company that can weld them up and turn them down to the right size.
Dennis Good drivers have dead flies on the side windows. (Walter Röhrl) |
That is about where ours failed - but track car for 10 years and large front wheels/tires - looks like a wear item - also 40 year old parts . . . IIWM replace with new parts . . .
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
ok so more information, I tried to put the disck with a brand new bearing while and torque it to the strut.
I can still feel a small play (which i can hear by the way).... So what are your last advice base on this ?(street car by the way) Thanks a lot ![]() a video migth be helpful https://youtu.be/gHA4KWRMScs Last edited by deftom; 01-23-2019 at 10:11 AM.. |
Spiderman
If you cannot tighten to no play then its done. They aren't the most expensive part to replace if you can DIY. Gotta take some stuff apart which honestly aint't that hard once you get after it. Go ahead and let the forum know you need to borrow a ball joint tool. I got one to use for the cost of shipping.
Thank for your help
.Everything is appart now, that's why I'm chechking everything. Last edited by deftom; 01-23-2019 at 10:56 AM.. |
Mine had a similar sized ridge and same issue, bearing tightened according to the book and still excess play. Yes, it's time to replace with new ones.
1986 Targa Guards Red 2021 MT09 SP |
Spiderman
And really, think about it. 30 years +/- ain't bad for any automotive part ! Mine are still original at 32 years old. Buddy of mine just had to do this because his mechanic could no longer get the fronts tight enough. First time replacement for him also.
deftom..Hi..do you know how to correctly adjust the front wheel bearings? Just asking;-)Did you pack the new bearings?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Hi Ivan
! that's a very good question. Yes I think I know how to adjust the front wheel. To be short, when I torque them " a lot", I can steel feel a play.Yes I did, I put lot's of grease like it's discribe on the pelican part arricle ! Last edited by deftom; 01-23-2019 at 12:14 PM.. |
ok..there are most likely toasted...the play you have is way too much..It is possible you or the person before ,drove too long without an adjustment?..again, just the Q.do you have the correct wheel bearing replacements?
ivan
Ho yes it's possible!
And yes I think I ordered the correct reference! I bougth them on Oscaro. |
i believe you know what you are doing..so if it was me, get it replaced ..it is afterall your baby 911..and the winter is long;-)
ivan
Counterclockwise?
Do you have a part number for this? I think I have the same problem and I'm doing brake work anyway.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Htnaks guys for all your input.
@Proporsche, you are completely right to question my method... I'm simply a curious amateur who makes certainly lots of mistakes. To give you a more accurate vision of my work; I'm rebuilding my front axel unit... and when it done I will do the back. Here is some pictures .![]() ![]() ![]() |
hi deftom..as an amatuer you are doing a great job ,I never thought otherwise;-)
Ivan
