911buff
911buff's Avatar
No start issues
I have a ‘71 911T that is giving me starter issues. Pulled the starter and had it checked and the selonoid was bad so I replaced with new starter. Worked great for half a day and now again car will not start. When I turn the key to the start position, power is being pulled because I can hear the fuel pump bog down. If I cross the terminals on the starter, cranks over hard. So, unless that selonoid is bad (haven’t had a chance to pull it and test it) I am guessing it is the switch. My question is how to trouble shoot the starter switch. Can I cross the 30 terminal to the 50 terminal on the plug? Or is there another way to test to determine whether switch or starter? Thanks
'71 914 1.7 - sold, '70 914-6 - sold (I am such an idiot!), '73 914 2.0 - sold, '74 914 2.0 - sold, '74 914 2.0 - sold, '67 911 - sold (Again, I am an idiot), '91 C2 - sold
Old 04-08-2019, 11:12 AM
It's probably a dirty ground wire from the trans to the body located at the forward part of the transmission.
A good troubleshooting technique for a 914, but can also be used on the 911:https://www.pelicanparts.com/techarticles/mult_starter_diag/mult_starter_diag.htm
Edit - they do have troubleshooting for the 911 that includes the ignition switch:
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/87-Starter_Troubleshoot/87-Starter_Troubleshoot.htm
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 04-08-2019, 12:29 PM
