Tell me about this oil cooler
Car came with it. I assumed it was a factory part until I saw the hole hacked in the front valance.
![]() ![]() ![]() W. Washer bottle relocated, so is the brake fluid overflow bottle. What do I have?
1973.5 911T ——-1974 914/1.8 |
Been here a while
looks like the air conditioning condenser
looking for 1972 911t motor XR584, S/N 6121622 |
Do you have any better pictures? Hard to tell what I’m looking at. The last one looks like the AC condenser and protective cover from a later car.
_______________________________ 1982 911 SC 240,000mi and counting |
If you have an SC the oil cooler would be a trombone shaped tube in the front right wheel well.
Walt 82SC 3.0 81SC 3.6 |
Looking at the front valance and his signature I doubt that’s an SC
1980 911 SC
Isn't that the blower for the front condenser? Its part of the A/C unit. The PO may have cut the hole to allow for more air to enter blower thinking more air would blow over condenser.
Life's a Beach |
Press the horn button. See if it plays this 'un?
Sorry if I appear I know nothing about the early 911's, it's because I don't... And very few in my area to ask.
The last two photos posted upside down. The AC condensor is attached to the underside of the hood/bonnet.
Vintage Owner
That’s an auxiliary AC condenser with the blower in the front trumkblowingdown through it. The oil cooler is under the passenger’s front fender in front of the wheel.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Pelican has some good Technical Articles on their Porsche 911 (1965-1989) Technical Articles page.
Porsche Air Conditioning Frequently Asked Questions page is good as well with additional links to explain the AC equipment and history. The early AC systems were dealer installed. |
Also, about that oil cooler in front of the passenger side front wheel - I'm pretty sure that in 1973 it was an option, and a T may not have come with one from the factory. So you may not have that on your car. Although with AC it is more likely you do. Should be the trombone style (looped tubing).
Mark
1979 911SC Targa |
I'll try to steal some garage time later today, raise it up and have a better look.
If that fan is non-operational, the A/C system, condenser side of the circuit is not protected as designed. Over pressure can occur
1980 911 - Metzger 3.6L 2016 Cayman S |
Great info. Pelican is a excellent Porsche information source.
Rescuer of old cars
The A/C in my '72 was factory installed, confirmed by CoA. Not hacked, all the holes are nice, factory quality.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
My COA confirms a factory AC also but stuff like SAE bolts, USA hoses, butchered holes for hoses and the front tow hook hacked off and almost perforated the front pan.
Rescuer of old cars
That's odd. My car did not have a front tow hook at all, and I've gathered that was normal for early cars with factory A/C. Much of what you describe doesn't sound factory, or at all what I've seen in mine so far. My install is definitely tidy, with perfectly round stamped holes, and is very professional looking.
