Senior Member
Brake Warning Light
Here is a pic of the light. I am reinstalling stuff, and want to make sure they are working properly. I understand the seatbelt light, from the owner's manual, except that I don't know when it (temporarily it seems) comes on. Does this light illuminate as soon as the key is turned, or does the engine need to be started?
Back to the Brake Warning Light. Please tell me how this works, and especially tell me how I can test that the bulb is working. Does it come on when the key is turned on, or when the engine starts? And finally, does this little hard-to-remove item have replaceable bulbs? If so, what kind of bulbs does it use and how are they accessed. Thank you.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Brake wear warning light.
On our M/Y 1986, the brake light has two functions.
1. The brake pad sensors will close a circuit when the pads are worn down to a dangerous level. test by shorting the pad sensor wires. 2. Also, when the E-Brake is set. Test by shorting the E-Brake switch. 3. As for the seat belt light, there is a relay which activates when the car is started. (I removed the relay from our car) I can post the circuit as needed. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 03-13-2019 at 05:52 PM.. |
Lights.
![]() ![]() ^^^^^ The multi function PC board. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
