calidude's Avatar
Here's the retest with the brown wire connected. Another fail but improved numbers. The O2 sensor looks like it's been replaced as not the original. I'm guessing it's CAT time
Old 02-18-2019, 04:51 PM
I recently sold an old Jeep wrangler (to buy a Porsche ) and had a similar high NO smog failure with the Jeep. New cat and it passed with no issues.
Best of luck!
1978 SC Targa
Old 02-18-2019, 04:59 PM
calidude's Avatar
Cap and rotor photos, looks rough...
Original wires too
Old 02-18-2019, 09:03 PM
scarceller's Avatar
Yes that cap/rotor needs replacing, get the OEM Bosch parts. The wires also look rough.
Other thing I suggest is take the car for a good drive then park it and remove the spark plugs. Check to see how all six compare with each other, post some pics here.
Because you are almost passing my bet is a new cat will get you to passing state.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-19-2019, 05:30 AM
proporsche's Avatar
i do not think the cap and rotor is your problem,neither are the spark plug wires.The cracks you see is the outside rubber cover not a cable itself...I would also make it a little richer before another test;..
Ivan
btw when they test it do they put the probe before cat or after the cat??It should before the cat for adjusting and testing after the cat...
1985 911 with original 502 191 miles...808 198 km
Old 02-19-2019, 08:59 AM
calidude's Avatar
They put the probe into the tailpipe for testing. I'm planning on replacing the cap, rotor and wires just because they are original.
I did some research on a CAT today and called a shop that said he could cut out the old cat and install a universal in it's place. He said they sell ones with flanges already attached too.
Pelican carries this - https://www.pelicanparts.com/catalog/SuperCat/911M/POR_911M_EXHMUF_pg1.htm
Appreciate any thoughts and help on going with a universal or the one above?
Old 02-19-2019, 01:36 PM
Porsche 935's Avatar
When I was a Porsche tech. We would set the idle and fuel mixture with a emissions tester. They normally are within spec from just this unless something mechanical failed.
3.3 ltr, stock compression, efi, twin turbo - no intercooler.
Old 02-19-2019, 01:48 PM
proporsche's Avatar
well? the best and cheaper solution would be if some of your CA neighbors pelicans can lend the cat for smog test..then put in straight pipe till next time ...
Ivan
Old 02-19-2019, 01:54 PM
scarceller's Avatar
Here's a thread with 100 cell cat
catalytic converter
Sal
1964 356SC (SOLD)
Old 02-19-2019, 02:00 PM
Still here
pmax's Avatar
Nice car. You chose wisely !
New CAT is just a few nuts and bolts away to install.
Here's the link to the approved list from the smog czar.
https://ssl.arb.ca.gov/AftermarketParts/catalysts
Old 02-19-2019, 02:53 PM
That Guy
Techno Duck's Avatar
I used the CA legal cat from DEC... it works fine.
Here were the results with about 7 miles on the cat, stock '89 chip, no vacuum leaks, rebuilt injectors, new cap / rotor / plugs, new O2 sensor and perfectly dialed in idle and CO adjustment using a wideband O2 sensor. Literally rolled right off the highway and pulled in for testing.
About 10k miles later, this time with a different tune...and the car sat for about 2 hours before it was tested.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-19-2019, 04:28 PM
calidude's Avatar
Ordered the DEC cat and gasket/bolt kit and should be here on Thursday ready for install. Thanks for sharing the same and those are good numbers I'm looking forward to sharing soon.
Old 02-19-2019, 11:44 PM
midnight911's Avatar
Go in with temp SUPER hot and the numbers should improve...
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 02-20-2019, 08:21 AM
scarceller's Avatar
I'm sure a new CAT will help pass emissions.
But what has my eye is the high NOx number, this is usually the result of a lean running condition.
I suggest the base mixture be checked and reset if need be. It can easily be done with a CO meter or better yet a Wide Band O2 gauge. If you use the WBO2 you should target a base mixture at idle of about 14.0AFR with the O2 sensor disconnected. Just follow the Bently manual for this procedure.
You really should double check the base mixture after you replace the cat.
Sal
1964 356SC (SOLD)
Old 02-20-2019, 08:40 AM
calidude's Avatar
Had some sweet victory today with the help of WTD mufflers and Poway Smog as the car is officially passing and registered in California now. The passing numbers are almost unbelievable and the old cat had a massive blowout inside of it.
Old 02-23-2019, 04:58 PM
calidude's Avatar
Car purrs like a kitten and no longer hesitates on acceleration
Cap, rotor and wires are next....
Old 02-23-2019, 05:03 PM
proporsche's Avatar
calidude..do not throw away the cat make it a strait pipe for you....just remove the inside filter...now you do not need a smog check for 2 year so put your strait pipe back in and you will like the sounds even better;-)
Ivan
Old 02-24-2019, 12:18 AM
Glad everything worked out OK. I was in the DMV when you pulled up and parked. Sounded nice!
Old 02-24-2019, 06:45 AM
calidude's Avatar
Thanks guys, would have enjoyed a convo with you hunter...
The car got a lot of attention at the DMV, a guy from Indonesia and I were talking about his trip to Germany and how he almost bought a 70's Mercedes SL convertible to ship back. Also another guy who was a veteran from the Navy was telling me about his being stationed in Germany and he used to see these on the Autobahn near his base.
I really like that about the car being a new owner now and how it's an opportunity to be humble to listen to people's history and why the car is important to them. That's pretty cool in my book...
Old 02-24-2019, 08:16 AM
proporsche's Avatar
calidude...well after spending most of my young live in California with those speed limits i did got caught up once coming from Ventura for 125/h at 4 in the morning;-)..now i have the autobahn 25 minutes from my house in Europe...
In Ca we also used to drive to Montana where there were no speed limits ,at least those days now i don`t know?
Ivan
Old 02-24-2019, 08:27 AM
