Perpetual Reassembler
2jmotorsports's Avatar
28 Tube Brass Cooler Internals
Had a 28 tube brass cooler cleaned and painted a few months ago.
I am just getting around to installing it when I stuck a flashlight into the holes and noticed something interesting in each tube. There seems to be a wire in every tube I could see.
I stuck my pinky in there and I could move each wire around in each tube bore but they do not move axially. Maybe they are looped around the closed bottom end of the cooler. Also if you gently tap the palm of your hand against the tubes you can hear the wires shake.
Any idea what these are for? Breaking up built up crud in the tubes? The things you notice when parts are clean!
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 02-23-2019, 09:06 PM
frankc's Avatar
I can't offer any suggestions on what the wires might be for, but I'm curious to see what responses you get as I have one of these coolers in my '77.
I had mine cleaned by Pacific Oil Cooler and don't remember seeing such wires, but I didn't inspect it very closely.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 02-23-2019, 09:26 PM
Guessing: helps convert laminar to turbulent flow, for better heat transfer.
'76 2.7-->3.2
Old 02-23-2019, 09:41 PM
Would definitely change the flow from straight to tumbly thats for sure.
Old 02-23-2019, 10:50 PM
Under the radar
Trackrash's Avatar
I'm guessing, as above, they are to improve the efficiancy of the cooler. FWIW I took apart an RX-7 cooler which had thin perforated strips of aluminum in each tube. I removed them all and welded the end cap back on. Can't tell the difference in operation.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-24-2019, 09:41 AM
Turbatrol used to have a cooler with internal fins. Apparently doing this to the oil makes it cool more efficiently.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-24-2019, 02:40 PM
Flojo's Avatar
do an ultrasonoic bath.
I did that and was astonisched how much dirt came out.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 02-26-2019, 02:26 AM
