You can also find a used one on eBay. I did for $65 and it works great! I think other brands of cars used this same control unit.
I knew it!! Engineer all the way
Mike |
transistors, diodes, and relays. |
I could get the Cruise Control back to work bij changing the 3 capacitors as described earlier in this thread.
However , 2 problems remain: 1. When setting the speed, say at 80mph, speed immediately drops some 8mph after releasing accelerator pedal and then CC kicks in and holds indefinitely on 72mph. Does this at any speed. Same when using the CC lever to go to a higher speed, I get immediate response, but as soon as I release it will drop some 8mph before CC settles in. FYI: I did check the servo cable setting and all seems fine (no clearance) 2. the reset function does not work. Anny suggestions where to look ? |
as a sequel to my previous post, replacing the 2 ICs (voltage comparators LM2901N) solved all remaining problems. :):):)
I noticed these ICs are mentioned 'no longer available' on many sites, I found them here digikey.be/products/nl?keywords=LM2901N%2FNOPB That is a bit more fiddly than replacing the condensors. Using desoldering copper braid is the trick here to absorb all the solder from the IC legs. Took me not more than an hour including removing and putting back the unit in the car. For longer distances on highway the cruise control is really nice to have, even in a Porsche. ;) http://forums.pelicanparts.com/uploa...1606235166.jpg |
Most likely just re-soldering in those areas fixed the problem, i.e. just re-soldering the board typically fixes the unit without replacing any components. |
resoldering every connection on the board. Very tedious, but it usually works. |
I could have taken the intermediate step of re-soldering the existing chips. Whatever, CC works great now;) |
| All times are GMT -8. The time now is 03:49 AM. |
