regular maintenance?
Could someone tell me what the regular (and or irregular) real-world maintenance would be (as in, $$ - more or less) between a, say, '78cs and an '84 Carrara?
This board has been such a blessing in getting info on what to look for as I search out my first Porsche- you guys and gals have been great (I just don't hope I wear out my welcome!) Thanks again. |
3-5k on on oil and valve adjsutments.....or once a year. Plugs....10k ish....pull them on every other oil change and check gap.
Trans oil....depends, banged on all the time....once a year. Brake fluid once a year, flush entire system..... Money wise in comparison to an SC and a Carrera....not much difference. |
I am not sure about the Carrera.
On my SC I adjust the valves every 6 or 7 thou. 10,000 would be about the norm though. Do plugs and rotor at the same time. Oil change every 3 or 4 thousand. So far, knock on wood, I have performed all required maintenance on my own. |
Hmm, are you asking what is done or how much it costs, the cost of on SC and Carrera will be similar on maintenance. I think I have heard people mention 1000-1500 per year, but I think that is for paying someone else to do the work. I don't think my Carrera is that much a year for "regular maintenance", now if you count unexpected costs then it probably avg about $800- 1200 a year. (tires, misc things going bad/breaking, etc...)
Jesus, I read Mikez's answer and thought I'm making a terrible mistake: 3-5k for an oil and valve adjustment! (then I saw he's talking about miles and not $s.) What I was really asking is if it's likely to cost more to keep an '84 going smoothly as opposed to a '78 (sorry for the confusion)
| All times are GMT -8. The time now is 02:03 PM. |
