gt-3
Looking for a GT-3 MUFFLER to put on this set of headers as well.Thanks Bump
I’d be interested in your headers Fred. You’vr mentioned the mathematical formula based on engine type and using Burns type collectors. Will your headers also be custom to each engine? Sell in pieces or do they come welded as 1 piece?
headers
Hi,thanks for your question.They will come ready to bolt on according to your engine size.Thanks Fred
Ok, so now I read more... you are looking for someone to make your designs...
Longshot: I think the water-cooled guys at Sharkwerks have some of their own designs. I think only water cars-- so likely no competitive situation. I do not think they have their stuff made in house. Not sure about volume. But in the interest of common love for things Porsche, it might make sense to give them a call as part of your networking. |
Will you be making any for 914/6?
I believe I could donate a GT3 muffler if you’d consider letting me be a header beta tester for my 2.7 RS? I can email you some pics....
We have a 914/6 section which includes headers and heat exchangers. |
914-6
Hi JMZ.I will just concentrate on 911 for now.I have done 914-6 for my tube frame 2.8 with 374 hp. & 249 ft lbs. of torque.Fred
Crazy numbers from a 2.8. How many hours would something like this be good for between rebuilds? |
life of a 2.8
I took the first one apart at 60 hours.Just replaced rod bearings which looked great.Center main was drilled to feed #2 & 5.Lapped the valves in.Has Ti rods & valves so less stress.Leakdown was excellent and left the rings alone.Has great oil cooling and has heating coupler to warm the oil.Well babied. After its first dyno run engine was taken apart for full inspection because of the build.Only change was to add a dowel pin in the crank for the flywheel.2nd one has never been apart but it is young yet.Fred
That's what I make www.914-6werkshop.com |
If Ole @ WeldingWerks in Orange CA hasn't early retired yet, he has welded many a custom spec header.
| All times are GMT -8. The time now is 04:52 PM. |
