Dave Ploss's Avatar
Ball Joint-REALLY need suggestions
I'm running out of ideas.
Because of the A Arm, I can't get the dremel to cut all the way through the castellated nut. I've got about 1/4 " to go.
ANY suggestions would be appreciated. I've tried hitting it with a chisel and hammer to try and spread the cut I made but no joy. I'm tearing up the nut pretty good. I just wish I could finish the cut. I have tried to cut it on the ball joint side to avoid the a arm but I can't get the depth I need. I hope this makes sense.
Thanks.
Dave
Dave Ploss
'87 911 Carrera Coupe - Black
'90 Mercedes 190E
'00 Filippi Lightweight Double
Old 03-16-2003, 08:20 AM
Chuck Moreland's Avatar
Hold the dremel at an angle such that you are not cutting fully perpendicular to the threads.
Failing that, drill through that last 1/4 inch.
Chuck Moreland - elephantracing.com - vonnen.com
Old 03-16-2003, 08:31 AM
Dave Ploss's Avatar
Chuck,
Thanks....why didn't I think of the drill thing.
Your bearings are going in next weekend. I'll let you know how it turns out.
Dave
Dave Ploss
'90 Mercedes 190E
Old 03-16-2003, 09:06 AM
