Dave Ploss's Avatar
Angry HELP!-Techniques for Dremeling off Castellated Nut.
I need help. Wedge bolts out and as usual, the castellated nuts are not moving. What is the proper technique for using a dremel on this.
I've cut one almost all the way through on two sides but can't get it all becuase the a-arm is in the way and I don't want to cut it. I've tried the chisel but I must not be doing it right.
Should I keep trying to cut it through and wht is the technique for the chisel?
Thanks.
Dave
This is actually easier than I thought....so far.
Dave Ploss
'87 911 Carrera Coupe - Black
'90 Mercedes 190E
'00 Filippi Lightweight Double
Old 03-16-2003, 06:44 AM
Jamie79SC's Avatar
Do you have room to hack saw it off? In situations like that, I use a little handle that holds a standard hack saw blade (not the full sized bow).
Jamie79SC
Old 03-16-2003, 09:37 AM
or maybe if your almost all the way thru, try using a big socket and try shearing the nut off...maybe itll just come right off...
ChadC
Old 03-16-2003, 09:43 AM
HarryD's Avatar
Dave,
HAve you tried using the Carbide tip that looks like a milling tool (not a wheel). You should be able to weaken the nut cut cutting in several spots to cause it to chip out.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-16-2003, 09:47 AM
