Front Oil Cooler Duct Mod
Many have done this mod for the RS Style bumper and oil cooler mods. Here's another one made from flat sheet. Actually I curved everything everything for strength. Here are a few photos
Once I get the actual oil cooler that I plan to use, I will also fab up some brackets and baffling so that the air actually goes through the cooler and not around it.
Overall, happy with the result so far.
Cheers,
Tom
www.ahhgaragetime.com
Old 03-09-2019, 12:51 PM
Here's the before pic, showing the lack of clearance.
Old 03-09-2019, 12:55 PM
Watched your video. Good stuff! Thanks for the information that will help so many others.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 03-09-2019, 03:33 PM
I just did this today. Converted short hood to long and welded in duct for oil cooler. Added tabs to mount oil cooler. First welding project so excuse the bad welding! I’ve been just winging it.
Old 03-09-2019, 09:09 PM
Nice Mark,
What Oil Cooler is that? I haven't purchased mine yet.
Tom
Old 03-09-2019, 10:55 PM
It’s a Mishimoto found online. Got it because it was the biggest to fit the area as I’m running a 3.6. It’s 20.5” long and just fits! I might have to shave the bottom brackets off. Also it looks like I can run the oil lines behind the bumper. I didn’t want to cut into the car.
Old 03-10-2019, 08:50 AM
BoxsterGT's Avatar
Porsche Crest
Here is my 71 911 with a Setrab Oil Cooler that clears the RS Bumper....
It required custom 30mm Oil Fittings and clears without chassis mods and uses the later A/C front crash bar as the main support.
Len dot Cummings at verizon dot net
Old 03-10-2019, 09:22 AM
Where did you get the AC crash bar support? I like that!
Old 03-10-2019, 09:26 AM
3rd_gear_Ted's Avatar
Originally Posted by tperazzo View Post
Nice Mark,
Tom
Whatever oil cooler you get, the bigger the inlet / outlet fittings, the better the flow.
I have a Setrab 72 row with -22 fittings for my track car 3.6 conversion.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 03-10-2019, 09:32 AM
BoxsterGT's Avatar
Porsche Crest
The support bar is a factory part for the mid 80's 911s.
More than enough room for air flow without cutting the tub, at least for a street car.
For the Track, what Tom has done is worthwhile and necessary.
Nice job Tom.
Len
Old 03-10-2019, 09:36 AM
Thanks Len, that's a good tip to repurpose the AC bar!
Old 03-12-2019, 12:03 PM
