Stophos's Avatar
Identify These Brembo's
These came with a project car and I am trying to determine what they are from so I can get what I need to mount them one my 77 project if possible. Can anyone tell definitively from the pictures?
Thanks in advance for your help.
- Chris
Looking for:
1969 911T - Engine - 6196603 & Gearbox - 7196742
1969 911S - 901/13 Gearbox - 7195559
Old 03-15-2019, 01:01 PM
sc sc is offline
sc's Avatar
The large calipers look to be "Big Black" or S4 calipers and should have piston sizing of 40/36.
The smaller ones you will need to measure the piston sizing since front and rear 993/ 964 standard calipers look the same and use the same pads.
Rear 4-piston sizing:
- 34/30 for 28mm width rotors- 964 turbo rears
- 30/28 for 24mm width rotors- basic 4 piston 993/964 rears
Standard front:
- 40/36 for 28mm width rotors- basic 4 piston 993/964 fronts
Old 03-15-2019, 04:04 PM
Bill Verburg's Avatar
- Chris
Most likely a set of normal 993 calipers
Bill Verburg
Old 03-15-2019, 04:06 PM
