Moses's Avatar
3.6 motor saga... distributor clues.
Well, Ingo suggested that the 993 motor should idle OK with either distributor connected, so:
I unplugged the coil wire from distributor #1. No change.
I unplugged the coil wire from distributor #2. Engine promptly dies.
Does this mean I'm running on only one set of plugs? Is this normal?
Thanks in advance for your help.
Old 03-16-2003, 10:44 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
that sounds like it very well could be the #1 dizzy
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 03-16-2003, 10:46 AM
has your drive belt between dizzys ozonated and snapped. #1 good . #2 bad.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-16-2003, 10:54 AM
Bill Verburg's Avatar
It should idle on either. You have a problem w/ the one set of plugs.
Bill Verburg
try to turn the rotor on the outeer distributer. If you can turn it you snapped the dist belt and it is not working.
Old 03-16-2003, 11:13 AM
hallo
Take the Cap of the Distr. if you can turn it free the Belt is broken .
This is the Distr. hanging free ,the other one has the Shaft going into the Engine . If that is ok take the Wire from the working Distr, and put it on the non Working . If it works now you have a Problem in the Circuit to the Coil .
Harald
If it's the belt Steve Weiner would be the guy to send it to
Rennsport Systems
Bill Verburg
Old 03-16-2003, 11:30 AM
