-   -   Installing RS panel and this happened (http://forums.pelicanparts.com/porsche-911-technical-forum/1023621-installing-rs-panel-happened.html)
Snitzler 03-14-2019 11:04 AM
I am installing RS door panels and I have this mismatch on the bottom where one of the the screws go. Actually I think another one is going to be the same. Any ideas, it is off by about 1/4" The black thing is the door panel and it is located by those plastic clips so the panel really cant be moved around.
http://forums.pelicanparts.com/uploa...1552586242.JPG
Cory M 03-14-2019 11:22 AM
You can either drill an new hole in the door, in the panel, or use one of these fasteners...
http://forums.pelicanparts.com/uploa...1552587750.jpg
wilnj 03-14-2019 11:28 AM
Enlarge the hole and use a rivnut. Even though the hole is now somewhat oval it should work since there’s so little load on the fastener.
madcorgi 03-14-2019 11:31 AM
Now that's funny!:D
dwelle 03-14-2019 02:12 PM
mine ('76) secured into a piece that backed up the door panel and move side to side at least a 1/2"...
juanbenae 03-14-2019 03:25 PM
are all the fastener loose? if not try loosening everything and slightly tighten in a circular pattern around the perimeter after seeing if it will offending fastener will go home. see if each one can give a little to make them all line up enough
blucille 03-14-2019 09:06 PM
as others have said, on my cars, the nuts in the door are mounted in slots (sort of) so they have some play or movement to them, a fair amount as I recall. Not all that different than the seat mounting points in impact bumper cars.
