-   -   3.2 Carrera - what to do's for reliability? (http://forums.pelicanparts.com/porsche-911-technical-forum/1023719-3-2-carrera-what-dos-reliability.html)
sp_cs 03-16-2019 07:51 AM
Originally Posted by Nick Triesch (Post 10392402)
What the heck are the two speed rev sensors?? I have an 85, never heard of this before.
I think that should be the speed ‘ref’ sensors (reference)
sp_cs 03-16-2019 08:06 AM
Check all engine bay hoses - breather and vacuum.
There is a circa 1” wide vacuum hose that joins the chassis in front of the engine, onwards toward the brake booster. Do check that - mine fell apart upon inspection ..
http://forums.pelicanparts.com/uploa...1552748731.jpg
da Vinci Dan 03-16-2019 11:40 AM
Every 30 years rebuild your axle halfshafts.
scarceller 03-20-2019 09:20 AM
Get the intake smoke tested, find vacuum leaks early before the cause real damage. Most cars I look at these days have some sort of intake air leak.
SpyderMike 03-20-2019 02:46 PM
fuel lines, fuel lines, fuel lines. My 1985 has had two major leaks and I found the third luckily before it happened. You say they were checked...but if they are original and 35 years old, I would change them before it is too late. My car has 250,000 miles and still runs fine.
famoroso 02-08-2021 04:38 PM
I just did this...
http://forums.pelicanparts.com/uploa...1612830836.jpg
So, I wish I'd had this...
https://www.rsrproducts.com/product-page/rsr-products-rear-sway-bar-mount-gusset-kit
New WEVO mounts getting welded up next week.
brighton911 02-08-2021 06:12 PM
Agree on replacing the 2 reference sensors, CHT, fuel lines, intake gaskets and also check the distributor bushings. My bushings at 100K were fine however, my brother in laws 911 at 100K found that the rotor was beginning to touch the cap due to the upper bushing being worn out. And of course - yes, drive it!
cassisrot 02-08-2021 10:39 PM
Originally Posted by Ian Comerford (Post 10392315)
I will add a very simple one, drive it often. These cars love to be used and do get better the more you use them.
This!
