Guest
Posts: n/a
When looking for backdating kits I have found that there is one for 78-83 SC cars and one for 84-89 Carrera cars. Basically what I want to know is: Why?
What is the difference? Are the flanges not the same for SC and Carreras? Is the bolt hole distance (up to the cylinders) different on SC/Carrera? Or is it something else that makes it necessary to have one kit for SC and one for Carrera? |
Guest
Posts: n/a
I just found out myself
Backdating heat exchangers for SC - has 36mm tubes. Carrera- has 38mm tubes plus they have thicker flanges and a small extension (collar?) that goes into the cylinder. |
Guest
Posts: n/a
Here's a picture of the extension/collar.
Mikkel, there is only one tube size
>38mm 1 1/2"OD Primary >34.9mm 1 3/8" ID primary >51mmOD 2" collector >42mmID 1 7/8" collector Weight 24lbs There are two different flange thicknesss, Carrera wants thick O2 is an option, but if it's missing it can be easily welded on.
Late model SC's also use the thick flange,my 83SC has thick flanges.I received my SSI's today,man they are a work of art!!!
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
