Senior Member
Engine Air Duct Paint
My fan, housing, strap and pulley parts are with Shaun at Tru6. The fan center, pulley and housing strap are being plated in yellow zinc, which is the stock finish. I am considering cerakote color choices now. When these parts return to me, they will be GORGEOUS. I am very excited.
The black sheet metal air duct pieces, such as the one which wraps around behind the distributor, look a little tired and will be remarkably ugly next to the new parts. So....I am taking them to a friend's shop today for sand blasting. Once the old paint is off, then I will paint them. I am looking for suggestions: I am not set up for spraying auto paint....no negative air paint booth, no HVLP paint gun. I will need to use rattle-can paint. However, I suppose I could have the auto paint store make me some special rattle-can or bottled two-part paint which can be loaded into one of those propellant set-ups (I forget the name) where the propellant is in a can and the paint is in a bottle attached to the can. I would prefer the simplicity of using plain old rattle can paint, if that can work. I have a can of the Worth satin black, which is a very Porsche-like finish. I imagine I should start with a primer that will work on metal. Perhaps an etching primer. Will this work? Can I get metal-etching primer at Home Depot? Can I just use that, then color the parts with the Wurth paint? What are your suggestions?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
![]() ![]() ![]() ![]() ^^^^^ Here's what I used. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Shaun has my fan/housing to refinish with cerakote, and a lot of stuff being replated.
had been wondering what to use to paint/refinish those fins for the alternator. also what kind of primer/paint to use on the big plastic cover. I'll be watching this for ideas and results.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
Personally, I wouldn’t use spray paint. I opted for a brush on paint because it goes on so much thicker. Obviously, cerakote or powder coat would be even more durable but this stuff goes on pretty thick, lays out pretty well and is an excellent match to the factory finish.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Kinda hard to see in the pix but it’s Sherwin Williams Satin black enamel.
I repainted the little plate that sits beside the fan (after making a hole for heater backdate). I spray painted it with high temp black paint made for charcoal grills. After 5 years it still looks fine.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Guest
Posts: n/a
As an alternative, Supe, you might try some of this two-part stuff I got from Wesco Auto Body (there's one near you!). I just used in on various parts of my car, including the wheels. Goes on well and dries really, really hard. Wear a chem mask though--it has some nasty hardener in it. ![]() I'll be excited to see how the parts turn out. I wish I had gone that route instead of powder-coating mine. They came out OK, but not as nice as Shaun's. |
Senior Member
For purposes of clarity, here are the two sheet metal duct pieces I want to paint. As you can see, I sand blasted them. My plan is to hand sand a little, wipe clean with lacquer thinner, prime with a metal-etching primer, then spray with Wurth satin black. Does anyone see a weakness in my plan?
Guest
Posts: n/a
Nope. Go for it.
