AC Icing Up on '86 Carrera
While driving from Austin to Houston yesterday afternoon I had the AC on - it ran solid for over an hour but eventually stopped blowing cold air. I popped the hood when I got home and saw a line iced up. Any idea what would cause this? Ambient temperature was about 80 and the humidity was low.
Sent from my Pixel 2 using Tapatalk
Noah
1986 3.2 Carrera | Iris Metallic Blue
2022 Macan S | Gentian Blue
Old 03-23-2019, 01:04 PM
It probably stopped blowing cold air because the evaporator iced up as well. Most likely due to a faulty thermostat or the thermostat probe becoming dislodged from the evaporator matrix.
You didn't notice the compressor was being run continuously and not cycling?
You could try running it at 3/4 of max cold setting rather than fully cold to see if that prevents the evaporator icing.
Old 03-23-2019, 02:53 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
A/c
Try these control settings.
Also, because it is almost impossible to determine
the compressor on/off cycle while the car is driven,
I added an LED across the compressor circuit as
an indicator.
Please provide additional data such as to when the issue sstarted,
refrigerant type, any A/C modifications ect...
Is the evaporator drain plugged up?
Your local A/C shop should have a look & hang some diagnostic
high/low side gauges.
Also, an open thermostat wire will not allow the compressor to engage,
which is not your problem.
Send a pm to Kuehl-He is the man!!!!
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-23-2019, 03:55 PM
scottrx7tt's Avatar
Could be a little low on referigerant
Old 03-23-2019, 04:24 PM
