Wheel spacers?
Looking to "fill out" my 911SC's wheel wells with a slightly wider stance. Have standard fenders and Fuchs. What size spacers can I use without danger of rubbing? Should spacers be on rears only or front as well.
Any advice would be appreciated. |
most here don't like spacers ... they won't pass tech at most events ...
except for the factory spacers .. But if you must a few pictures would help .. or at least the numeric info off the back of your Fuchs ... and the amount of "space you are trying to fill .... |
RETIRED
Spacers OK in most cases as long as there are enuff turns on the lug nuts. Most racers use open headed nuts. Stud should be flush or extend past.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I have 21mm H&R spacers on the rear only on the 88 Carrera. Fills things out very nicely. Stock wheels all around.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
Unless you have wider than factory flares installed on the front you would probably be better off not using any spacers but that's up to you.
I believe 21mm spacers are the widest you can go without having to install longer wheel studs on either end of the car. If you have 8 inch rear wheels the 21mm spacers do a great job of moving the wheel/tire combo outboard for a wider stance. Your ride height might be the factor regarding any rubbing. Post some ppics and we might be able to help even more.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
The best solution (abet a ‘bit’ more cost) is to buy two 8x16 rear wheels, moving your current 7x16 rears to the front.
Not only will this ‘fill out’ the fender opening but add a subtle ‘wide wheel’ look and support the (standard) tires better. To ‘fill out’ even more, you can use wider tires on the wider rims. Some searching will find a lot of examples of this. There are more disadvantages of simply adding spacers and moving the center of the tire contact patch outboard. Most significant is in the front due to caster and bump-steer effects. Even in the rear, the more cantilevered forces increase the stress on the rear wheel bearing. A lot of engineering has gone into the correct placement of the contact patch in relation to the movement of the suspension and steering. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
21mm spacers, stock sc, 7" fuchs
no spacer ![]() spacer ![]() no spacer ![]() spacer
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
It took only 49 years!
Serge: In the heart of Philly! Daisy - 1972 911T 2.7L Light Yellow Veronica - 1987 911 Carrera Coupe Indischrot, M&K GT3 muffler and Euro Pre-Muffler, SW Chip SOLD ![]() Lil Blue - 2002 Subaru WRX Wagon (my dd/HPDE car) SOLD
nice guy
I like stock.
You could just measure how much stud protrudes on the stock setup and subtract 21mm to see if you're happy with the remaining thread engagement. My open wheel nuts are 20mm deep so I'd want about 41mm protruding without spacers to be happy not to put in longer studs.
Wheel spacers?
Thanks Johner - I should have thought to check that before asking - if my memory serves correctly my open lug nuts sit just past flush with the end of the lug stud so there is no way I have enough stud length to support 21mm spacers. Looks like I need to decide between replacing studs or using wheel adapters. Last edited by Schloer2; 03-28-2019 at 09:14 AM.. |
