-   -   Turning light not working. (http://forums.pelicanparts.com/porsche-911-technical-forum/1024922-turning-light-not-working.html)
yuth 03-28-2019 04:31 AM
My turning lights not working with the light switch on (head light and dash). It works fine with the light switch off. Any ideas . Thanks
JSV798 03-28-2019 12:06 PM
Are you testing with the engine running? If you are just switching the ignition on and off with the headlamps switched on the this might just be low battery voltage. You will have noticed that the headlights come on only when the ignition is on (engine running or not). If you have ignition on (but engine not running) and indicators working and then put on the headlights the drop in voltage might be the problem. How good is your batter? What year is your car?
yuth 03-29-2019 12:49 AM
79’ SC. Yes the car was running. It works when the engine and lights off.
yuth 03-29-2019 01:14 AM
