Turning light not working.
My turning lights not working with the light switch on (head light and dash). It works fine with the light switch off. Any ideas . Thanks
Are you testing with the engine running? If you are just switching the ignition on and off with the headlamps switched on the this might just be low battery voltage. You will have noticed that the headlights come on only when the ignition is on (engine running or not). If you have ignition on (but engine not running) and indicators working and then put on the headlights the drop in voltage might be the problem. How good is your batter? What year is your car?
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
79’ SC. Yes the car was running. It works when the engine and lights off.
