DustySC
83 SC LED signal problem
Hello! I’ve been stalking and getting incredible info from the forum both pre-purchase and post-purchase of my 83 SC coupe (bought in June of 18).
I have a few issues, but one I’m wrestling with now is the front turn signals after an LED upgrade from CarMagic. All bulbs are replaced, the relay and the indicators in the tach. All are working properly, except the front signals when the lights are on. When the lights are off, all good. When on, the blink very weakly - the light actually stays on the very faintly brightens. Also, the front side markers don’t work- however, I can’t be sure they ever did? Finally, maybe unrelated, the interior lights now don’t work... Any help is appreciated! |
Are you saying the LEDs are bright on running lights then only get a little brighter on turnsignals?
When lights are off, are the turnsignals as bright as when the lights are on? The turnsignals should be independent of the interior lights. Sounds like another issue.
Find Spoke's LED Products: www.spokeworksled.com |
Have you changed the flasher relay. You’ll need an ep 26 I believe.
78 911 st backdate 87 944 00 996 |
DustySC
Spoke- yes the LEDs are bright on running lights, then only get a little brighter on signal. With lights off, the signals are as bright as with lights are on- they work correctly.
Sebscst- the flasher relay has been replaced, Th aks guys! |
Wonder if LED's are worth the trouble sometimes. I put them on both my 914's and they work fine. Put them on my '72 911 I'm finishing the restoration on and have a weird issue I can't resolve. Have replaced the flasher relay and the blinkers, emergency flashers all work fine, but the relay is constantly clicking anytime the ignition is on, whether any lights are on or not. Turn the key on, the relay starts clicking... luckily the car is noisy enough you really can't hear it when driving, but it still drives me nuts!!
1971 914- original owner 1973 914 2.0 2018 911 carrera T 2016 981 Spyder PTS |
DustySC
With my turnsignal LEDs I've taken a different approach and made very large boards to fit in the entirety of the turnsignal cavities. This gives enough room on the PCB to mount resistors to make sure the running light intensity is much less bright than the turnsignals. ![]()
DustySC
Is the front signal, with lights on, supposed to full off / on when the indicator is activated (or go from on to brighter on)? |
As a test try swapping the brake and front turnsignal LEDs to see if either looks correct (dim/bright) in the other socket.
