Flywheel question. Re install or new? 1 tooth missing.
Putting the motor back in my 964. It never had and issue with starting. Just noticed the flywheel is missing 1 tooth.
reinstall it or get a new one?(if I can even find one) Thanks guys
A few P-cars in the garage |
You know the answer.
I don't know about Porsche or the 964 specifically, but generally the ring gear is removable and replaceable on the flywheel on most cars in my experience.
Brew Master
Depends. How much do you drive it? Do you mind taking it back apart when, not if, it fails?
Nick |
Let's say the next tooth goes missing too...
yes the ring gear is removable and replaceable on the 964
I think that maybe I'm dreaming.. |
do not think twice ,it is around 140 bucks here is your part number
964.114.143.02 Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Not to be silly, but since you mentioned that the car started fine: You know there are two sets of "teeth" and one of the sets of teeth is supposed to have one missing to trip the flywheel sensor. Is the starter gear missing a tooth, or is the trigger wheel missing a tooth? One is a big problem, the other is exactly as it should be.
New-ish 911SC Targa Owner
These are as they should be:
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Hi
No brainer. Replace it.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
Red Line Service
smokntr6, Exactly my thoughts.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
Put the flywheel sans ring gear in the freezer. When frozen, heat up the ring gear with a flame or the oven. When hot, it will drop onto the cold flywheel.
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold |
Best place to purchase a new one? Porsche said 1400.00
Check the picture, smokin6 has the flywheel answer and Pamp picture shows the missing tooth on the motronic flywheel
Bruce |
Here is it. I guess I need to find a new one for the best price. Any sponsors here?
again why not new 140 Bucks is not much,or?
Ivan
did i say 1400 i have written 140 bucks ,mama mia ,above is a part number and check it with pel.parts
Ivan
here is one on ebay for 150 ...here is the number
401492380636
When you get stranded it won't be in your driveway or even close to home.....
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
