-   -   questions about heat exchanger R&R (http://forums.pelicanparts.com/porsche-911-technical-forum/1025326-questions-about-heat-exchanger-r-r.html)
steve meltzer 04-01-2019 12:05 PM
Just pulled the rusty heat exchangers and rusty Bursch muffler from my '74 Carrera When i put the new heat exchangers on, do you put RTV on the metal gasket that goes between the HE and the cylinder head? If so, i'd presume you'd use the orange stuff.
Antiseize on the barrel and hex nuts or locktite or noting?
Ditto the RTV question where the heat exchanger meets the muffler. There'a a gasket between the two.
thanx steve
911pcars 04-01-2019 12:18 PM
Gaskets can go on dry. Yes, apply anti-seize to all threaded fasteners.
Sherwood
steve meltzer 04-01-2019 06:41 PM
thanx again. steve
