1987 carrera...
before dismantling the steering wheel from its base...i would like to hear from you first... When I hold my steering wheel with both hands and shake it up and down or side to side, the whole column moves approx 1/4 of an inch. however turning left or right there is no gap, the turning itself is tight! Any opinions as to the source of the issue? |
There's a bushing in there, it's probably shot. There was a Pelican (Leland?) making stiffer replacement bushings a few years ago. I put one on my car and it works as intended.
What Cory said - Mitch Leland steering bushing, right here on Pelican for $30.00 -
Steering Column Support Bushing, Self-Lubricating Nylon, 911/911 Turbo, (1974-89) Part #: PEL-ML-STR I have one as well - it works great.
'87 Carrera, Granite Green, SW Chip, Dansk sport cat, Kuehl A/C |
yep -- here's a link -- https://www.pelicanparts.com/More_Info/PELMLSTR.htm?pn=PEL-ML-STR
be sure to take a bit of time once the wheel/old bushing's off to pick/push out any of the bits of disintegrating old/original bushing that you can find. I had what sounds to be exactly the same problem with my '86 and this bushing completely resolved it for me |
Did this just on the weekend. Takes 20 minutes to fix. Make sure you get /have a 27mm socket before doing the work. Maybe also disconnect your horn or battery unless you want the whole neighbourhood to know you are working on the steering wheel.
To make it easy for reinstalling the steering wheel, I marked mine with a marker. It's easy to get it one tooth off.
steering movement
Thanks guys...Mitch Leland bushing ordered from our host.
Would love to read the instructions if someone has one to share... |
Search within the forum “steering wheel bushing” or Google “Porsche steering wheel bushing Pelican.” There are a number of helpful hints largely pertaining to assuring that all of the old bushing is removed before placing the new bushing. Not doing so will lead to an ill-fitting bushing and having to dig out the remainders of the old bushing that have been tamped down. I have links buried somewhere, but a search should get you where you need to be.
Ass-engine Nazi slot car -- PJ O'Rourke |
SC |
Pulling the relay in the frunk fusebox is the easiest way to go.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
steering not firm
1987 carrera...thanks for your support! just finished installing Mitch Leland bushing.
the Video was excellent making the work easy and fast. BTW, I used my vac. cleaner to get rid of all plastic particles. |
Give your self a treat ! Install some turbo tie rod ends , Wow what a difference !
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
steering movement
I have the turbo tie rods for over 10 years now...thanks for suggesting
