-   -   spring for MFI throttle body (http://forums.pelicanparts.com/porsche-911-technical-forum/1025710-spring-mfi-throttle-body.html)
gptom 04-05-2019 08:17 AM
I am looking for the part number for the spring that helps close the throttle plates. there are 6 used. I checked ETCA, but the exploded parts diagram did not break them out. I could see them drawn on the throttle body
TIA
Tom
manbridge 74 04-05-2019 10:58 AM
90111013102, leg spring. About $15 each
Jonny042 04-05-2019 02:57 PM
I think 90111013102 might be the single spring for the crossbar, not the x6 ones for the individual throttles.
manbridge 74 04-05-2019 04:02 PM
Except in PET it shows quantity required is (6) so I think that’s it..
Jonny042 04-06-2019 06:55 AM
I missed that. If you google the part number some good images come up, and it should be easy to determine which it is.
I won't be over to the shop till later but if I think of it I'll look at both of them and see if I can figure it out.
BURN-BROS 04-06-2019 07:16 AM
That number is for the crossbar. Porsche does not offer individual parts for the throttle bodies. I service throttle bodies so let me know if you require service.
gptom 04-06-2019 08:09 AM
does anyone know the specs for the spring? wire diameter etc
1QuickS 04-06-2019 08:37 AM
It would not be hard to make some springs, there are only six. I've made them in the past. All you need is one spring to use as a master, a little trial & error development can resolve your issue. If your shafts are loose then check out Aaron Burnham for service, Post #5.
gptom 04-07-2019 11:00 AM
I am fighting a slow to get back to idle after slowing down. so far I have cleaned & greased all of ball/sockets & replace the bushings for the lever arms.
The springs are very rusty, so I thought I would replace them
