gptom's Avatar
spring for MFI throttle body
I am looking for the part number for the spring that helps close the throttle plates. there are 6 used. I checked ETCA, but the exploded parts diagram did not break them out. I could see them drawn on the throttle body
TIA
Tom
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 04-05-2019, 09:17 AM
Functionista
manbridge 74's Avatar
90111013102, leg spring. About $15 each
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 04-05-2019, 11:58 AM
(man/dude)
Jonny042's Avatar
I think 90111013102 might be the single spring for the crossbar, not the x6 ones for the individual throttles.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-05-2019, 03:57 PM
Functionista
Except in PET it shows quantity required is (6) so I think that’s it..
Jeff
74 911, #3
Old 04-05-2019, 05:02 PM
(man/dude)
Jonny042's Avatar
I missed that. If you google the part number some good images come up, and it should be easy to determine which it is.
I won't be over to the shop till later but if I think of it I'll look at both of them and see if I can figure it out.
Old 04-06-2019, 07:55 AM
BURN-BROS's Avatar
That number is for the crossbar. Porsche does not offer individual parts for the throttle bodies. I service throttle bodies so let me know if you require service.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 04-06-2019, 08:16 AM
gptom's Avatar
does anyone know the specs for the spring? wire diameter etc
Old 04-06-2019, 09:09 AM
1QuickS's Avatar
It would not be hard to make some springs, there are only six. I've made them in the past. All you need is one spring to use as a master, a little trial & error development can resolve your issue. If your shafts are loose then check out Aaron Burnham for service, Post #5.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 04-06-2019, 09:37 AM
gptom's Avatar
I am fighting a slow to get back to idle after slowing down. so far I have cleaned & greased all of ball/sockets & replace the bushings for the lever arms.
The springs are very rusty, so I thought I would replace them
Old 04-07-2019, 12:00 PM
