Help - it won't roll
He all, Just picked up a 75 911 with a 3.6 and a built 915. Great car but I am working out some bugs as the car has sat for a bit.
LOL, So, maybe I need to hit the gym or something, but all kidding aside, I can't roll the car much at all. I jacked it up and its not sticking calipers, its something tranny related I think. Right rear tire, can be turned forward with huge effort (and left rear also turns forward) and If I try to rotate the left rear tire (again, significant effort to do so, and the right wheel does not move). I have seen some tight trannys in my day, but nothing like this. I can barely move the car in neutral.... All that said, it does roll OK when driving and I don't feel anything binding.... Thoughts? |
You have parking brakes in the rear as well, maybe they have seized?
Rutager West 1977 911S Targa Chocolate Brown |
Hey West, yes the car has parking brakes, but i don't feel them binding... its feels like its in the tranny...
Still here
How's the clutch ?
Clutch feels great and its not slipping
Disconnect both C.V. joints from the trans flanges. That will tell you for sure if it is the trans or something else.
Rob |
Thanks Rob, Will do
Otto, car runs great, although you can feel just a hint of drag when you first take off, kinda like the car has a spool or a really tight diff... This is mostly an issue when pushing the car around the garage |
If the offset is wrong a tire may be rubbing against a strut, unlikely but worth a look.
Thanks Ed, but tire is not running..... Its between the tire/wheel, and the tranny... Brakes are not binding
