Oh Damn!!!!!
I need some advice guys.... Battery was dead in my teener. Haven't driven it for a couple months...so........I was trying to push start it this weekend. After many unsuccessful attempts, the last time I popped out the clutch, it didn't turn over the motor.........JUST A TICKING SOUND!!!!! Is it possible that I stripped the splines on one rear hub.....or worse.........blew out first gear?????? Let me know what you guys think. I still havent bought a battery....or looked at the car after that. IM SCARED!
Mike
Old 03-17-2003, 03:01 PM
Jbabic's Avatar
I had a problem today, i didn't have second gear but had third and no forth....I find out my spline on my coupler to the Tranny mount was loose enough for first gear but would just slide back and forth...I tighend up the bolts...and wow...all my gears...
This is coupler under the carpet behind the seat in the middle...under the plate....don't know if that helps....but may be a simple solution.
Old 03-17-2003, 04:03 PM
Send a message via ICQ to old_skul
I'm sure you've tried another gear, mikey?
I have had good luck push-starting my car in reverse. Regardless, get the battery charged and see how your tranny is.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 03-17-2003, 04:37 PM
Team California
speeder's Avatar
FWIW, it's always easier to push start a car in 2nd or 3rd, better reduction/ turns motor easier.
Denis
"It won't interfere with the current building. It'll be near it but not touching it." -Grifter in Chief, July of 2025
Old 03-17-2003, 05:33 PM
the mainshaft often breaks off under the little 1st gear, when doing burnouts, and other somewhat abusive stuff. hopefully that's not the problem. does reverse still work?
206 637 4071
Old 03-17-2003, 06:38 PM
slater's Avatar
You know, for a while my only car was a 77 MGB. I tell you what, you have never truly lived until you have had a car you had to puch start every morning to get to work. I just started backing up my driveway with a little slope, that way i could just push my car really fast and then jump over the door (convertible) and pop it. ...Good times.
Anyway, what kind of "ticking" was it? I had a car once with an electronic ignition box that would tick for a sec as i started it. I would get a battery and try it out.
1977 MGB (bright yellow)
1985 Honda Spree Moped (great for towing rollerbladers)
A flute without holes, is not a flute. A donut without a hole, is a Danish.
Old 03-17-2003, 08:35 PM
..well...it was a bad ticking........When I pushed the car up the incline by my garage door, I put her in reverse to hold the car......wel.....it didn't hold her........it ticked down the incline while in reverse....not turning over the motor mind you.....@%#@%@ !!!!!
Old 03-17-2003, 08:43 PM
ouch. hopefully the clutch disc sheared instead of the main shaft. have you tried to start it yet?
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-18-2003, 05:24 AM
For the next time.....( maybe this will help others, too)...
Notice that when the engine is driving the car...1st gear allows the engine to spin fast and the car "slow"....normal gear-ratio mechanical advantage...
So...when you're push starting...think of the forces occurring in the "opposite" direction...therefore you'd like third or fourth gear...something that woudn't put so much strain back into the box. Car's wheels will turn easier relative to the needs of turning the engine to life.
Pretty much what speedr said....
Hope it's not the overhanging first gear set... if it's a 901 box..
--Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-18-2003, 11:52 AM
i never roll start or jump off. i use a battery charger, drive another car or call a wrecker
Old 03-18-2003, 12:41 PM
i just said that because the clutch comming apart sounds way cheaper than the mainshaft. just hoping for the best.
Old 03-18-2003, 02:38 PM
