Positioning of sump plate on 83 sc
I've read, several times, that the drain plug on 83 sc should be at 9 o'clock. (Drivers side)
I'm in the process of changing mine since it's at 6 o'clock and I noticed the drain plug lines up with the curved tube coming through the screen. If I rotate the drain plug 90* it obviously will no longer line up with the hole in the screen and the curved pipe. Is that going to be a problem? Thx Hugh |
I believe the sucking up of oil will be higher than the magnetic force downward to pull metal out of the oil.
I have never put the magnet in alignment with the scavenge pickup Bruce |
Bruce[/QUOTE] So then it's just a coincidence that my magnetic plug is set up the way it is? Would it have left the factory that way? It certainly seems odd as all that I've read indicates it was wrong. Maybe set up that way by a previous mechanic? Thx |
What the ?
On my 80sc the sump plate can be mounted in the wrong orientation which won't allow proper flow at higher speeds but my plate does not have a drain plug I have to remove it completely during oil changes.
SCWDP 73 1980 SC Harley Davidson Road King 9/11/01 FDNY/343 Never Forget! |
facing front.... on the right of the strainer plate...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 04-09-2019 at 12:06 PM.. |
When you say " on the roght" do you mean passengers side , or do you mean the other right ie drivers side? It seems I have read to place drain plug on drivers side but then I don't see where there would be a difference. Thx |
most of the drain plugs you will see are ,facing the rear of the car on left ,that is drivers side..not HRD 911..PEt even shows it in the 6 o'clock..so let me correct my above writings ...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Ivan,
That PET image may be of the old style sump screen. With the new style, the drain plug has to go on the drivers side, 90-degrees to the case seam. I'm pretty sure a 1983 came with the new screen, seen here: 3.2 SS engine oil pump Mark
1979 911SC Targa |
Venturi type sump screen.......
+1. People who have used the Venturi type sump screen on their motors are familiar with the drain plug orientation. To avoid confusion using left or right side, I recommend to people to orient the drain plug towards 1-2-3 cylinders. This will both apply to LHD and RHD 911 cars. Tony |
I'll try to post pics of what I have.
The sump plate, with drain plug, is separate from the domed screen. The domed screen has an opening for the oil pick up and that was directly over the drain plug. I can see where having the pick up directly over the drain plug might cause some restrictions so moving the drain plug under cylinders 1 2 3 would make sense. |
Sorry, tried posting pics from my phone but no luck
I will go ahead and rotate my sump plate 90* and I'm sure there will be no harm done. Cheers. |
I just had a look at my 1982 engine to let you know which way around mine is and the sump plate doesn't have a drain plug at all.
Also I thought '83 engines didn't even have the sump plate and looked like the bottom of a 3.2 engine. |
The owners manual for my 81 SC shows plug to the rear
Rob |
Now might be a good time to remove the sump plate and see if the filter/mesh on the pump pickup needs cleaning. this way you can be 100% sure you have it on the right way when it goes back on.
Senior Member
This conversation usually revolves around incorrect orientation of the "bowler"-style anti-cavitation screen that nestles into the sump. That screen's large molded hole must be oriented to the driver side where the pump pickup can be positioned through it for oil pickup. The bolt itself can probably be oriented anywhere.
As background, by 1983 the anti-cavitation "bowler" screen setup was in all of the SCs. The issue for earlier cars (like my '78) was the movement during hard turns of oil away from the driver side-oriented oil pump pickup, causing temporary scavenge loss and lack of oil to the engine. See here: http://forums.pelicanparts.com/uploads25/image1462390442.jpg
'78 Targa in Minerva Blue |
My other ride is a C-130J
1983 SC s were manufactured with the 1984 3.2 Carrera cases towards the end of the Model Year production, so early 1983 SC s did have the sump plate.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupι 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A Last edited by RNajarian; 04-09-2019 at 08:50 PM.. |
Ivan
scumbag
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
Coram Deo
Pictures really help. The opening is for the pump pickup. If you line up the opening with the pump pickup, the dent lines up with where the plug has to go.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Since I've now decided how I'm going to proceed with the re-installation of the plate my question is do we use some sort of sealant on the gaskets during reassembly?
Thx |
