Senior Member
Superman's Avatar
Heater Handle Knob Replacement
As I recall, long time ago here, somebody soaked their heater handles in red dye, then repainted the white part. Excellent results.
I am far too lazy (or busy, depending on your perspective) for this. Our host sells these for $15. I'd get them if I was confident they are easy to get off/onto the levers. Can anybody report about ease of installation?
Mocha 1978 911SC. "Coco"
Old 04-14-2019, 02:52 PM
Installation is just tapping back onto the lever. I’d spend a few more bucks for the aluminum version from Rennline.
The sun and heat not only fades the color, but makes the handles brittle. Getting them off isn’t much of a problem. Getting them off in one piece might be.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 04-14-2019, 03:24 PM
piscator's Avatar
How ironical! I started attempting this 1/2 hour ago and gave up. So I'll be very interested in the answers.
I have a feeling that in removing them, they'll be destroyed. It's probably not worth trying to save them, but I'm going to use a heat gun and try to tap them off with a hammer and drift punch.
Robert
"A man must consider what a rich realm he abdicates when he becomes a conformist." ~ Ralph Waldo Emerson ~ (thanks to Pat Keefe)
Old 04-14-2019, 03:38 PM
Try wrapping something like paracord beneath the base and pull in the same axis as the lever while tapping on the handle itself. I should add that I had my seats out when I pulled the handles off so it was a bit easier.
Old 04-14-2019, 03:41 PM
And one of mine did crumble at the base, but I had replacements in hand.
Old 04-14-2019, 03:42 PM
Senior Member
Superman's Avatar
We don't get sun and heat here, and I like the look of the originals. It sounds like they might come off in pieces, maybe, but are otherwise easy to install.
Old 04-14-2019, 05:36 PM
Wildman Emeritus
I did they dye thing years ago. Has held up well.
Just took a crescent wrench, adjusted it to lever thickness, put a cloth between it and the handle and tapped with a hammer. Similar to removing shift knob. Came off easily and with no damage.
However, I did not brush the lettering; painted the face and carefully wiped the surface leaving the recessed lettering filled.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 04-15-2019, 06:51 AM
I'm good with tools.
AG81's Avatar
These are cool...My factory handles were a serious PITA to remove. But I got'r done.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 04-15-2019, 07:31 AM
I went all-black, too.
Old 04-15-2019, 07:52 AM
if you are not worried about saving the originals ... dremel them off
1981 930 euro
SOLD 1980 911 targa euro
Old 04-15-2019, 08:00 AM
joe payne's Avatar
I always thought Rennline should make these. Billet aluminum with an allen set screw. DONE.
jtp911
Old 04-15-2019, 02:28 PM
MARISOL78sc's Avatar
They do!
Rennline Aluminum Heater Control Knob-Rennline, Inc.
Paul
2011 Cayman S | 1978 911 SC | 1975 914 | 1987 951
1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold
Instagram: @rennsport98
Old 04-15-2019, 05:00 PM
schoward's Avatar
I put in the ones in the original post with little issue. At the time my originals were around 24 years old and badly baked and faded (targa car and PO lived in GA and FL).
Tapped the old ones off which came off pretty easy. Firmly slid on the new ones with a tiny dab of superglue applied to the metal levers for extra security. Haven't budged in 15 years and still look great. I can't recall it being more than a 15-20 minute project, but sounds like I was lucky.
Scott
1981 911SC Targa - Platinum Metallic
Old 04-16-2019, 08:05 PM
Formerly known as Syzygy
Canada Kev's Avatar
If you haven't got your old knobs off yet, instead of trying to pull them off, try using a pair of pliers with the jaws straddling the heater lever or arm right behind the knob. Them with a light hammer, tap your pliers to knock the knob off the end of the lever.
Kevin
Old 04-16-2019, 08:52 PM
