Free minder
Aurel's Avatar
Hood shocks trick
Has anyone ever purchased new hood shocks only to find out they are still too weak to keep the hood open? I had this issue, and I solved it for $2.10 at Ace hardware. Just replace the pins by slightly longer bolts, and double the shocks on the passenger side, reusing your old shiocks. You don’t have to double both sides, just passenger side works fine, and voila, hood stays open easily now .
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 07-05-2019, 11:07 AM
New-ish 911SC Targa Owner
pampadori's Avatar
my hood stays open fine with one on each side, however i used this same trick on the decklid when I replaced it with one with a whale tail. Two shocks held up the extra weight just fine there.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 07-05-2019, 11:18 AM
proporsche's Avatar
Aurel..your hood shocks are upside down....We used to do this in the 1980`s but what will happen is this...you latch will get worn out from this much pressure on one side.Eventually the corner of the front hood will come up due to the press on it.I recommend to replace also the other side..and put the shock the correct way...if two of then do not hold the hood up your-even new -shocks are not good.
Did you get the name Stabilus shocks??
Basically stay away from double shocks on one side....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-05-2019, 11:54 AM
I agree with Ivan about not doing double shocks on one side. When I bought my 86 it had a turbo tail with two shocks on the drivers side only. The deck lid was noticeably twisted. Took a good body shop to straighten it.
Old 07-05-2019, 12:43 PM
sky1jord's Avatar
Cool trick, Thanks
1958 356A - Sold to a rust collector
1978 924 - sold to a sewing machine repairman
1984 944 - meticulously maintained but everything except the drivetrain self-destroyed. Used in trade for my wife's MB
1988 Carrera 3.2 Targa - purchased in 1992 and still thriving. Boy, do I love this car
Old 07-05-2019, 01:35 PM
aualexa2's Avatar
My shocks were shot and I installed the rennline mechanical shocks. Never have to change shocks again!
Rennline Fully Mechanical Hood Strut-Rennline, Inc.
Alex
‘73 914 1.7 Phoenix Red
'99 SPB #79
'16 Cayman GT4 GT silver
Gone: '87 911 Blk/blk sunroof coupe, '13 991S Dbm/ag non-sunroof coupe
Old 07-05-2019, 01:54 PM
scumbag
Those are slick, but my first thought was if the wind rocked the hood back far enough to un-click those shocks, it's coming down in a hurry. I reckon there's not too many reasons to leave the hood open, but that's definitely what I thought of immediately.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
Old 07-05-2019, 01:59 PM
proporsche's Avatar
aua...I must say nice stuff..but 100 bucks for 2 shock is a lot
Old 07-05-2019, 02:02 PM
Diss Member
Quicksilver's Avatar
I have hood lights so there is no way that hood shocks will do it.
I have a wooden dowel.
If "new" hood shocks don't hold open a stock hood there is something wrong with them. I wonder how long they sat on a shelf somewhere.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-05-2019, 02:36 PM
Good point!
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl
Old 07-05-2019, 03:28 PM
If there is any bondo in the hood the hood shocks won't last long. Especially bad if it's in the front where the nose usually gets dinged. I installed the Seine hood prop and being carbon fiber it added a few ounces to the car. Still have the old gas struts in place to control the closing speed.
I'll see if the link will make it through: Seine Systems > Ultimate Strut
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 07-05-2019, 03:29 PM
Still here
pmax's Avatar
Nice work.
I assume you are pairing the new with the old shock, with the old on the extended lever.
But hah, Ace hardware parts ? Someone will ding you for that sin, not me !
Old 07-05-2019, 03:43 PM
It’s ok, ace hardware imports their bolts from Germany.
78 911 st backdate
87 944
00 996
Old 07-05-2019, 03:47 PM
gptom's Avatar
the mechanical shocks are similar to the 356 type. How many 356 hoods were bent by someone assuming they are gas shocks and pushing down. just saying
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 07-06-2019, 11:30 AM
Been here a while
this is what is keeping me from doing the change as well....every other car I own, hood or trunk is operated by gas struts, certainly I am a creature of habit....aren't we all?....and I've owned plenty of 911's with gas struts, how long before I learn which car has a mechanical strut and how much potential damage will I do?
So, the better question is, I've never replaced gas struts on any car, hood or trunk except 911's.....and EVERY 911 I've ever had has needed new gas struts. If I really cared, they would need to be replaced every year to keep the trunk lid open. I've bought the heaviest duty ones, stabilus usually....brand new, they would last me less than a year before the trunk lid starts to droop again.
I have a massive collection of mostly-worn struts
looking for 1972 911t motor XR584, S/N 6121622
Old 07-06-2019, 11:45 AM
Walt Fricke's Avatar
I once had a nifty plastic sort of lock on a hood strut. Open the hood, and a finger would slide over to block the bottom of the strut. Press the finger out of the way, and lower the hood. Didn't last long due to vigorous attempts by other to close it.
My broom sticks are usually close to hand. I really should make a rod (not as nice as the commercial carbon fiber one)which is installed and pivots.
Old 07-06-2019, 12:45 PM
midnight911's Avatar
my solution.
i prefer not having the shock working where you no longer need to push the hood down. just drop it few inches and it locks up.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 07-06-2019, 08:42 PM
In the 80’s you could buy these cheap little plastic lever arms that clipped onto the (failing/failed) strut to manually hold it open. The plastic arm was strong enough to hold any hood or hatch and only required you slightly lift up before shutting the lid. If you forgot and slammed the lid the clip would be pushed by the lever arm and release before any harm could be done.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 07-06-2019, 10:35 PM
Under the radar
Trackrash's Avatar
My carbon fiber hood stays up fine with those new wimpy hood shocks.
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-07-2019, 11:44 AM
Thread Killer
Teutonics's Avatar
Originally Posted by midnight911 View Post
my solution.
Okay, that's a slick idea!!!
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 08-06-2019, 08:26 AM
