bcgreen's Avatar
What tool used for door arm rest lid?
The area is very tight for removing the phillips head screw and none of my short screw driver heads are short enough.
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 04-20-2019, 03:37 PM
L-shape screw driver would do the job.
Old 04-20-2019, 03:41 PM
bcgreen's Avatar
I have a bunch of those as straight tip but no Phillips.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 04-20-2019, 03:43 PM
https://www.harborfreight.com/8-piece-right-angle-screwdriver-92630.html
Old 04-20-2019, 03:51 PM
bcgreen's Avatar
Have you used this tool for this specific job?
It looks like the head is too fat to sit flush against the screw.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 04-20-2019, 03:59 PM
I’d have to go take a look .
I have this set along with a dewalt set made for use in a drill (homedepot) in my garage .
Have a disassembles set in the garage right not , and Cannot remember what I used but probobly this .
Old 04-20-2019, 04:08 PM
How about a picture, don't know what screw you are referring to.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 04-20-2019, 04:20 PM
dreichman's Avatar
I use a tool very similar to yours. Works fine, just have to fiddle with it a bit.
Old 04-20-2019, 04:44 PM
scottrx7tt's Avatar
Remove the map pocket. And all screws are accessible
Old 04-20-2019, 05:02 PM
dreichman's Avatar
Old 04-20-2019, 05:10 PM
bcgreen's Avatar
How do you remove the pocket?
I was trying to remove the pocket to straighten it and thought I need to remove the lid. So I was looking for whatever screws I could find and it looked like the lid screw was the only screw holding the lid and pocket to the door card.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 04-20-2019, 05:50 PM
Fleming's Avatar
Kind of a rube goldberg ....
1/4' ratcheting box end with a phillips bit is about the shallowest I have used in similar conditions.
After you collect all of those changeable bit screw drivers you will have a variety from 3/4" to 3" bit lengths....all 1/4 inch hex.
hth.
Old 04-20-2019, 06:03 PM
I am also in the process of trying to figure out how to remove the door pockets. Look at the the PET diagram below. I am thinking screws 12, 16(multiple), 20, and 25 need to come out.
The question I have, will the door latching still work with the pocket removed?
Who, What, When, Where, Why and How.
Old 04-20-2019, 07:20 PM
bcgreen's Avatar
The rube goldberg thing worked and now that I have it apart I can see how everything comes apart. I used an adjustable wrench since I didn't have a ratchet that would work with bit.
Now the other side will go much quicker.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 04-20-2019, 07:39 PM
Care to share any tips on how to get the door pocket off?
Old 04-20-2019, 08:15 PM
Unless I don’t recall, all I’ve ever used to take a pocket off are Phillips screwdrivers. The lid and handle stay on unless you want to remove the door card.
Old 04-20-2019, 08:41 PM
