should a 86 carrera have a trans shim between the mount and trans?
Title say's it all. Thanks
Old 04-23-2019, 07:21 AM
proporsche's Avatar
i would say no but you will see soon different opinion.
For me the mount-center pipe- meets the body is should be flush with it...mind you the trany bolts are not that long...i do not always relied on PET..even there is only one...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-23-2019, 07:31 AM
I don’t recall seeing them on aluminum transmissions from 1978 on
I have a 77 mag trans and it has a spacer.
Bruce
Old 04-23-2019, 07:52 AM
Thank's Bruce that explains it.
Old 04-23-2019, 08:22 AM
Walt Fricke's Avatar
The spacer can help keep the sway bar from being too close to the mount. It can keep the two big transmission mount bolts from bottoming into the chassis mountings. I have trouble seeing them as necessary for alignment of the shift shafts, which have U joints and the aluminum spacer is not very thick. But they appear to be a stock part for the SCs.
The PET for '86 shows the spacer at part 2, but there is no 2 over where the part numbers are listed! Maybe the diagrams were just recycled?
For the 78-83 PET, part 2 is shown, but listed by PN only for the Turbo.
For the 74-83, part 2 is shown and listed as for every model.
For the '72-3, the plate is shown.
For the '70-71 911 transmission, two smaller, two hole plates are shown.
Old 04-23-2019, 12:00 PM
