What plugs do you run in your early 930?
Subject says it all, which plugs are you using with good results? engine is '77 930, stock.
Thanks,
Colin
Old 03-19-2003, 08:46 AM
I run the stock Platium plugs. WP30 or something like that. They list for $16 each-ouch
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-19-2003, 04:28 PM
Cheap, like me, single electrode Bosch $4 platinums. Not recommended by what I have read, but has worked ok for the last 20k miles. The Nippondensu (??) $5 plug are suppose to work well and are similar in design to the $16 Bosch plugs.
Tinker
P.S. Goran is right. The NGK is an other plug that I was thinking of, not the Nippon. Used by alot of racers with good results.
Old 03-19-2003, 08:35 PM
beepbeep's Avatar
NGK B8EGV or Bosch WP3O
Thank you for your time,
Old 03-20-2003, 03:13 AM
