Engine mount washers
When fitting engine mounts is it necessary to fit the curved washer or should the engine mount on its own be ok
Old 04-22-2019, 12:44 PM
The washer is a absolute must. Some say the curve go's up, some say down. The factory recommended that the curve faces away from the mount back in the 70's. Don't know the consensus these day's.
Old 04-22-2019, 12:54 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The current installation has the dish of the washers facing toward the mount.
Kevin L
'86 Carrera "Larry"
Old 04-22-2019, 01:20 PM
rokemester's Avatar
Useful post! Subject of controversy. Mine are installed
Concave down on 3.2.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 04-22-2019, 06:48 PM
I just changed my mounts at the weekend and had 2 washers on engine mounts but only one (lower) on the transmission mounts. I take it there are meant to be 2 in both locations?
Old 04-23-2019, 07:04 AM
proporsche's Avatar
i have seen most of the time since the 1980`s only 2 on bottom that is about 1000x 911`s...it could be different by the location and mechanics in the regions too....pet shows only 2 on bottom but lists 4 ...;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-23-2019, 07:33 AM
KTL KTL is offline
Schleprock
KTL's Avatar
PET parts diagrams for transmission suspension say there’s four washers. I’ve seen four on all three 911s I’ve owned
Kevin L
'86 Carrera "Larry"
Old 04-23-2019, 07:45 AM
Thanks, that's helpful. From service records it seems like the transmission on my car last came out in 1998 so 20 years with only 2 washers on trans mounts.
Old 04-23-2019, 10:13 AM
seafeye's Avatar
I’ve seen a motor fall out because washers were not used. I wouldn’t have believed it unless I saw it with my own eyes.
What me speed?
Old 04-23-2019, 10:24 AM
proporsche's Avatar
of course the engine mounts have 2 on each .....
Ivan
Old 04-23-2019, 10:31 AM
