-   -   Steering column help (http://forums.pelicanparts.com/porsche-911-technical-forum/1027507-steering-column-help.html)
fishfan009 04-23-2019 05:09 AM
Hi Guys,
I'm taking apart the column, and am having trouble getting these pan head bolts off. I can't get a regular socket on them. Anybody have any tips?
Thanks,
Rob
http://forums.pelicanparts.com/uploa...1556024896.jpg
76FJ55 04-23-2019 07:40 AM
Those are shear head bolts. the intent it for the head to shear off when the bolt reaches desired torque and then leave a smooth round head so that they can't be removed to prevent theft. You have a couple options, a chisel and punch will usually knock them loose, just place the punch at the edge of the remaining head and tap with a hammer in the loosening direction. Another option is to slot the head with a Dremel or hacksaw blade and use a large flat blade screw driver to remove them.
fishfan009 04-23-2019 08:23 AM
Makes sense. Thanks for your great explanation!!
