1989 911 3.2 Porsche broke down
I'm sure this mechanical question has been asked before hope u guys can help me out. I haven't driven my 1989 911 3.2 in about three weeks I was out of town. Today was a really nice day so the wife and I decided to take the 911 out for a drive. She started right up pulled her out of the garage let her idle for about 10 mins then she died I started her right back up after a couple of cranks which isn't normal then she idled fine. I was like this has never happened before but she started up and ran. About 1.5 mile down the rode she died for good now where stranded had her towed to the house. Any tips what it could be? it acted like it ran out of gas. Car had 1/2 tank of gas plus I added a couple gallons didn't help
Old 09-04-2021, 05:17 PM
sugarwood's Avatar
Saved by the spare DME relay !
1986 Bosch Icon Wipers coupe.
Old 09-04-2021, 06:04 PM
Originally Posted by sugarwood View Post
Yes first thing to try would be the DME relay. When it gives up the fuel pump stops and it runs out of fuel. It'll crank over but not start. Push back the front seat, remove and replace.
Davin
'87 Carrera 3.2
'66 VW Camper
'59 VW Beetle
Old 09-04-2021, 06:38 PM
proporsche's Avatar
Also ,do not let the car idle for 10 minutes not good and not necessary;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-05-2021, 02:56 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
As others said the DME relay controls power to the DME (stage 1) and power to the fuel pump (stage 2) and these are known to fail. Having a spare is a good idea because it’ll allow for a quick swap test. You can also make a temporary jumper that simulates a good DME relay all powered up. If that makes the car start you found your issue w/o throwing a part at it. Do a search here, plenty of information how to bypass a DME relay.
Next it’s time for some diagnostics:
- is there power to the DME (vibrating ICV, with key in ON) - if not check alarm
- is fuel and spark missing or only one
(brake cleaner into air box and see if it catches)
(test light to spark plug wire or spare spark plug watching for spark)
If both are missing check the flywheel sensors, resistance and signal
If no fuel check DME relay, fuel pump, filter, fuel pulses (NOID light)
If no spark check coil, spark pulses with test light.
Cheers
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 09-05-2021, 08:11 AM
Replaced the DME relay car fired right up Thanks for all the help!
Old 09-05-2021, 11:16 AM
Three weeks is enough time for mice to wreak havoc on your Carrera.
Old 09-07-2021, 12:25 PM
