TurboRuf's Avatar
Can anyone identify this turbo?
I was wondering if anyone could identify this turbo in the photo below? The intake housing looks much larger then the exhaust side. Thoughts… guesses?
Old 03-14-2003, 09:20 PM
TurboRuf's Avatar
85 930 Ruf BTR
Old 03-15-2003, 10:11 AM
beepbeep's Avatar
Hmm...compressor-housing looks like plain vanilla KKK K27 or 3DLZ, turbine-housing might be little smaller (K-26 hybrid?) but to me it looks pretty stock.
Can you post numbers off the turbo?
Thank you for your time,
Old 03-15-2003, 10:42 AM
Amac's Avatar
Hard to tell from this angle.
Looks like K-27 compressor, the hot housing looks like
a K-23 from a TT.
With the size diff. could also be a K-29 compressor
with a K-26 hot housing.
Both would be Hybrids.
What's it on?
"Never go faster than you can stop"
85 - 930 (750hp)
Norwood motec 3.5 twin turbo
Old 03-17-2003, 12:36 PM
TurboRuf's Avatar
The turbo is on a 930 that has been highly modified. The engine has been punched out to 3.5 liters, twin-plugged, GHL heat exchangers, etc.
Does the K-27 compressor housing have the multiple ribs on the top compressor port (see photo)? Every K-27 I've come across only has a single rib/lip on top.
What would be the advantage of a hybrid turbo?
85 930 Ruf BTR
Old 03-18-2003, 04:32 PM
Amac's Avatar
I've seen them both ways, you can get adaptors
to match the neck with porsche down pipe.
K-28, K-28s, K-30, are all hybrids. The turbo builders
mix the compressors and hot housings to get more
boost, or quicker spool up. I run a K-30 on my car.
85 - 930 (750hp)
Old 03-19-2003, 09:31 AM
