Banned
911 SC sunroof doesn't close properly
I bought an 1978 911 SC with a sunroof and I can't make it to work properly.
Problem is - it doesn't close. It's super slow and sounds very pained. So I've put out anything, cleaned and greased anything, tried a different motor. Nothing has changed. The wires/cables look great, if the motor is not attached to the gear/transmission part it doesn't sound so pained, it spins fast and compared to my other car (where I got the spare motor from as a test motor) - sounds the same. The rubber thing looks good. Any idea what I could try? |
Administrator
Hey Martin - check out the link below to a tech article from our site; it may give you some good info in helping you troubleshoot.
https://www.pelicanparts.com/techarticles/911_sunroof_repair/911_sunroof_repair.htm |
Have you tried closing it with the manual handle instead of the motor? It may highlight the problem
Ian |
The black link between motor and trans may look good but has possibly failed.
Bruce |
Banned
Banned
Banned
Ian |
Banned
Hi Martin..did you remove the sunroof and the cables or just lubed them..if not, i suggest to remove the cables all the way out....or come to Carlsbad -CZ and i will fix it for you;-)
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Banned
I did remove everything, cleaned it, lubed it - so I guess there isn't anything in the way .. We'll see, I keep you updated!
Martin make a video and let me see it;-) what did you use for lubrication??..
yes nice trip Hotels here are very cheap;-) and of course good beer;-) Ivan https://www.karlovyvary.cz/en
