Broken 964 distributor belt cost 37 hp
Stupid $8 distributor belt that broke on the dyno cost 37 whp. That’s the actual power loss while on the dyno. And that’s hp at the wheels! I guess after 25 years it was due for replacement.
Our host overnighted the new belt, now just have to put the dizzy back together and into the car.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Registered Minimalist
The power of dual spark.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
On my 964 3.6 the only symptom of my broken belt was intense pre-ignition knock on hard accelleration from low RPMs. Certainly not good for the motor. Had me perplexed for a bit till I found it!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Good it was caught Ed, can lead to some new pistons and rings.....
Yes, important from a power point of view as twin plug ignition timing advance is reduced because of the far better ability to ignite the charge. This also add greatly to rod bearing life especially in high rev/load use. The more power you can make at the least advance the better for rod bearings. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Yup, in my case though the knock sensors looked like they were working overtime constantly pulling back spark, the dyno plot for that pull were all over the place, not a smooth curve. And I was running 100 octane Sunoco Cam2.
I suggest inspecting all distributor components carefully, including bearings. I had one fail and the eventual result was a broken crankshaft.
Mike PCA Golden Gate Region Porsche Racing Club #4 BMWCCA NASA |
Mike, bearings looked and felt ok so I put it back together just to get back on the dyno. I’ll order up new bearings and do a full rebuild in a month or so, just have a time constraint right now. But good thought, thanks.
