Used Oil Cooler Question
Hi guys, I recently picked up a used Carrera oil cooler for my 83 SC from a pretty reputable parts company. It looks surprisingly clean (no dings, dents, or even flaking paint), and supposedly came off a "running" car.
It definitely hasn't been cleaned (nor was it sold as such), and I'm having difficulty finding a radiator shop that can clean and pressure test. I'm fine hooking it up and finding out if it leaks, but I am concerned with any contaminants that might be in it from the engine it came off of.
I'm sure I can flush it in my driveway, but in the event I missed something, does anyone know the circulation route of the oil from the front fender cooler? Would any contaminants be caught by the filter before hitting the engine?
Thanks for your help!
Old 05-03-2019, 01:57 PM
Red Line Service
Marc Bixen's Avatar
We strongly recommend having it ultrasonic cleaned and pressure tested. Check with a local race shop or aircraft mechanic for someone in your area.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 05-03-2019, 02:16 PM
I'll definitely defer to what Tony said below!
1978 SC Targa
Old 05-03-2019, 03:18 PM
Oil flow circulation path........
Sig,
All the oil flowing through the auxiliary cooler and subsequently enter the oil tank has to pass through the oil filter. Any debris or dirt in the oil is screened or filtered as the flowing oil enters the oil reservoir. That is the main purpose of the oil filter. It is always safer to use an engine oil cooler with known history (tested and cleaned).
Tony
Old 05-03-2019, 03:19 PM
arbita1's Avatar
When I rebuilt my engine I had the oil cooler cleaned and tested by pacific oil cooler. They did a nice job on it.
http://www.oilcoolers.com
Matt.
83 911SC
85.5 944 NA - Sold
Old 05-03-2019, 03:48 PM
Reiver
Reiver's Avatar
Whatever way you go this is a great addition...I have the factory unit on my '83 SC Euro and run in the Phoenix area summers….rarely hits 210 but only on a 110 degree day...
91 today and ran hard after an oil change...hit 110 mph....oil temp 190...it generally runs 100 degrees hotter than the ambient temp.
I switched the fan to a toggle switch under the dash by the ash tray to control when and how I want it to run.
You will have to move your trumpet horns forward is you keep them.
Nice change....one of the best for an SC.
De Oppresso Liber
Strength and Honor 5th Legion
Old 05-03-2019, 04:14 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Power to the 15th, Pacific Oil Cooler. Period.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 05-03-2019, 05:35 PM
Thanks, guys! Great information and advice!
Old 05-03-2019, 06:37 PM
The 9 Store
Sending a cooler to a place like pacific oil cooler is cheap. Even if it should be fine, why risk a $10-20k engine on saving a $150-200 service.
All used parts sold as is.
Old 05-03-2019, 07:26 PM
This. Get it pressure tested and professionally cleaned. Engines are just too expensive to gamble with.
Old 05-04-2019, 08:31 AM
Reiver
Reiver's Avatar
This....
De Oppresso Liber
Old 05-04-2019, 08:38 AM
Another +1 for Pacific Oil Cooler. Great people to work with and quality work.
Old 05-04-2019, 04:56 PM
Location: behind the redwood curtain, (humboldt county) california
+ Pacific oil cooler
I have seen many happy users of Pacific, on this thread and on the Ferrarichat forums. I have a couple of 308 coolers I will be sending to them this fall.
Chris
Old 05-04-2019, 06:27 PM
BoxsterGT's Avatar
Porsche Crest
To answer your original question about flow direction, the inner fitting (as mounted) is the IN, and the outer fitting is the Return.
And YES, Pacific Oil Cooler is the best choice, and worth every penny.
Len
Old 05-05-2019, 06:22 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
I will be sending my oil cooler in to Pacific Oil Cooler and I think i may have a leak up in there. Hopefully they can find it and repair it. In the unfortunate event they cannot repair it, is there a member on the forums that can provide a good used one?
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 05-06-2019, 10:22 AM
Perpetual Reassembler
2jmotorsports's Avatar
Pacific Oil Cooler pressure tests and repairs coolers. If you give them a description of your suspected leak they will test for it, repair, and validate it.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 05-06-2019, 10:40 AM
