3.6 conversion tins?
anyone know where i can get 3.6 conversion tins? i'm looking for the piece that seals the corner near the power steering pump/cam cover. if you're facing the front of the car it's on the passenger side and forward.
1967 911 (Azzuro Thetys) - #308439 1971 911 (PTS Black) - Built 3.6 Sleeper 1989 911 (Grand Prix White) - Cabriolet Bone Stock |
Patrick Motorsports sells a complete fiberglass kit for the 3.6 conversions. Most guys fab a set from a 3.2 motor from what I've heard. That's what my mechanic did.
1980 911SC Targa 3.6L |
G50,
I modified the 964 tins that came with my 3.6....here is a pic of what I did at the former power steering pump location. I used aluminum to make a block-off plate.... ![]() |
I did exactly what pdtweeks did when I completed the build of my 3.6 last summer.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Northern Motorhead
Made my own tin as well here ... i think i combined parts of the 3.2 and 993 bits that came with the engine.
I know the ready made parts from Patrick Motorsports are close to $1K , so i would suggest you make your own !
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
This is my plan as well. I have the 3.2 tins, as well as the 993 tins.
I'll make it all work, though I prefer to use the 993 tins over the 3.2 tins if possible. I wish there were more detailed write ups on this swap. I see three or four companies that offer most of these swap parts, and each claim to be better than the others, without giving a proper explanation as to why they are better. |
I use an old leaky oil cooler and cut out 3/4 of it so it’s just that upper shell. Mounts onto the factory location and looks correct when you look in the engine bay.
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
great ideas fellas. my issue is i don’t have neither my 3.2 or the 964 pieces so i’ll have to fab it from scratch
i took a look at pms’s set up and i don’t see a fiberglass option.
Northern Motorhead
Check the classifieds , lots of used engine tins available ... it would be a start !
